cbarberis
Joined: 01 Oct 2003 Posts: 172 Location: Punta Gorda, Florida USA
| Question on handling LCD menu data |
Posted: Tue Mar 07, 2006 5:21 pm |
I have done some searches on menu AND lcd and did not find an answer to some of my questions, So I thought I would pose this to some of the very competent people in this forum.
I am working on a laboratory temperature controller that is capable of running 10 user programed temperature programs with up to four cycles or steps for each program. I have already done a similar thing in the past, but without all of these added program menu pages, so it is not easy to adapt what I had done in the past with this new requirement.
every program contains four pages with a set temperature XXX deg C and lapse time in HH:MM each of these parameters are stored in EEPROM data memory (PIC18F4620) so the user can call any of the programmed sequences. Luckily, all the data is in a single byte int, except temp is a signed 8 bit int. All this information is displayed on a 4X20 alphanumeric LCD and I use four keys for input (Select, up, down and enter)
ie;
PROG: Pr01 STEP: n
Temp: xxx deg C
Time: xx Hr xx Min
STOP___ NEXT___ PAUSE___
where x or n is a displayed settable and readable variable and Pr01 is the page prog name
I guess my question to all of you is basically; what is the best and cleanest method to do this in terms of handling the data and handling the menu tree. I have done something similar but much simpler in the past, but perhaps not very elegant. Any creative suggestions are greatly appreciated.
For data handling, I though of using an enumerated progname and then have a simple structure that contains the temp, time in hrs and time in min, create 10 instances of this with four instances each or 40 sets, something like this: ?????
typedef struct ProgSeq{
signed int8 TempSet;
unsigned int8 TimeHRS;
unsigned int8 TimeMin; };
struct ProgSeq Pr00[4],Pr01[4],Pr02[4],Pr03[4],Pr04[4],Pr05[4],Pr06[4],Pr07[4],Pr08[4],Pr09[4]; |
Posted: Wed Mar 08, 2006 4:26 am |
As shown, your typedef an structure declarations are wrong. A 'typedef', creates a synonym for the type following it, so the typedef (if done right), already includes the 'struct' declaration. The simple answer to the rest though, is why not just use a two dimensional array?.
So:
typedef struct {
} Prog_Seq;
//This creates a new data 'type', called 'Prog_seq', which is a structure
//containing the times.
Prog_Seq programs[4][10];
//This generates a variable 'programs', containing 40 (4*10) Prog_Seq structures.
This makes it easy to access each of the four sub times, for each program, and the ten programs.
The values are accessed as:
programs[n1][n2].TempSet
etc..
