dlc@frii.com
Problems with the 16F628 USART |
Posted: Tue Feb 21, 2006 1:15 pm |
Hi all,
I've set up the USART of my program with a 4MHz internal OSC to run 9600 bps which is supported according to the PIC data sheet. However, the data sent is being corrupted. I use TeraTerm on my box to read the data. I get the first four or five characters correct, the rest is then just garbage. Can anyone tell me what I'm missing?
Much appreciated. Here is the <short> code, the same code I've posted in another query, but this is a different question so I thought it deserved another thread.
thanks,
DLC
#include <16F628.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP,NOCPD,NOBROWNOUT,MCLR
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1)
#use fast_io(A)
#use fast_io(B)
#define MAXBIT 13 //5 address, 7 control and one junk timing
int rise[MAXBIT];
int rW=0;
int gotOne = 0;
//save_w and save_status are at 7f and 7e which are available in ALL banks
int save_w;
#locate save_w=0x7f
int save_status;
#locate save_status=0x7e
#byte status = 3
#byte TMR1L = 0x0E
#byte TMR1H = 0x0F
#byte PIR1 = 0x0C
#byte CCPR1H = 0x16
#int_global
void isr(void)
#asm
//store current state of processor
MOVWF save_w
SWAPF status,W
MOVWF save_status
BCF status,5 //Set to page 0 for SFR's
BCF status,6
#endasm
rise[rW++] = CCPR1H; //save the pulse time
if (rW == MAXBIT)
rW = 0;
gotOne = 1;
TMR1L = 0;
TMR1H = 0;
#asm
// restore processor and return from interrupt
SWAPF save_status,W
MOVWF status
SWAPF save_w,F
SWAPF save_w,W
BCF PIR1,2
#endasm
int x;
int n=0;
set_tris_B(0x03);
set_tris_A(0x00);
//Turn off comparator
setup_ccp1(CCP_CAPTURE_FE); // Configure CCP1 to capture falling edge detection
setup_timer_1(T1_INTERNAL); // Start timer 1
for (x=0;x<MAXBIT;x++)
rise[x]=0;
enable_interrupts(INT_CCP1); // Setup interrupt on falling edge
printf("SONY IR decoder\n\r");
if (n)
output_low(PIN_A1);
n=0;
output_high(PIN_A1);
n=1;
if (gotOne)
printf("\n\r%u %u counts ",x, rise[x]);
gotOne = 0;
_________________ --
Dennis Clark dlc@frii.com
http://www.techtoystoday.com
Posted: Tue Feb 21, 2006 1:35 pm |
According to the 16F628 data sheet, in Table 17-4, Parameter 4,
it says the nominal 4 MHz internal RC oscillator can vary from
3.65 to 4.28 MHz. That's at least 7 or 8% off. That's beyond
the 3% maximum allowed. To be safe, you should limit the
error to 1%. |
Posted: Tue Feb 21, 2006 3:02 pm |
PCM programmer wrote: | According to the 16F628 data sheet, in Table 17-4, Parameter 4,
error to 1%. |
I noted that, but I've never had a PIC be THAT far off that it corrupted the serial data stream. However, I tend to write my own bit-bang code so perhaps my code is more forgiving than the USART is.
thanks,
DLC |
dlc@frii.com
Posted: Fri Feb 24, 2006 10:14 am |
error to 1%. |
You nailed that one. I assumed that the F628 had a calibration byte like the 12F and 12C devices to tweak it in. I find no mention of a calibration byte nor a calibration register in the F628. A 10MHz ceramic resonator later and my serial ops work fine.
thanks,
DLC _________________ --
yes Guest
Posted: Fri Feb 24, 2006 2:47 pm |
I had same problem with 4 Mhz....i didnt tested at 10MHz...
I had changed registers value to control tha operation, but nothing good..
628A does not that problem...INT_RC works very well...
Bye |
