russr
| Soft RS-232 baud rate 115200 not being generated correctly?? |
Posted: Thu Feb 16, 2006 4:28 pm |
I am using a PIC16F876 with 20mhz oscillator. For several years I've used PCW v3.045 and the following code has worked w/o problems:
#include <16f876.h>
#fuses HS,NOWDT,NOPUT,NOBROWNOUT, NOLVP, NODEBUG
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use delay (clock=20000000) //20mhz
// PortB OUT
#bit TXD = 6.4
// PortB IN
#bit RXD = 6.5
#use rs232(baud=115200, xmit=PIN_B4,rcv=PIN_B5)
setup_adc_ports(NO_ANALOGS);
set_tris_a(0); //all out
set_tris_b(0xE1); // 1110 0001
set_tris_c(0xFB); // 1111 1011
printf("Initilization was successful!\r\n");
while (true)
printf("test\r\n");
We recently upgraded to PCWH v3.224 and the above code does not work correctly...specifically, nothing is getting printed out to the hyperterminal screen. If I lower the baud rate to 9600 and recompile, it works like I'd expect. As mentioned above, the same code with baud=115200 compiled on v3.045 works. I'm using a MAX3380E leveler/inverter chip. I've tried upgrading to v3.225, but same problem.
Any ideas? I suspect that the baud clock is not being generated correctly with this new compiler version. |
Posted: Thu Feb 16, 2006 4:42 pm |
| Quote: | | We recently upgraded to PCWH v3.224 |
My records show that PCM vs. 3.224 came out on approximately
April 26, 2005. Vs. 3.225 came out on about May 27, 2005. |
russr
Posted: Thu Feb 16, 2006 4:48 pm |
| PCM programmer wrote: | | Quote: | | We recently upgraded to PCWH v3.224 |
You r correct, we purchased it back in May, but didn't get around to actually testing out this feature until recently. Anyway, I'm not really sure what this has to do with the problem I posted. |
Posted: Thu Feb 16, 2006 5:30 pm |
I just wanted everything to be accurate.
Anyway, I tested vs. 3.224, and the baud rate is incorrect. I was able
to make it work by changing the "baud" parameter in the #use rs232
statement to 109000. With a 20 MHz crystal, this generates a baud
rate of 115482 for a soft UART. This is only about 1% off, so it works
OK. I tested both transmit and receive with Hyperterminal.
Example:
| Quote: | #include <16F877.H>
#use rs232(baud=109000, xmit=PIN_C6, rcv=PIN_C7, FORCE_SW)
char c;
printf("Start\n\r");
putc(0x55); // Used to measure Tx baud rate
// c = getc();
// printf("%c", c);
russr
Posted: Fri Feb 17, 2006 8:20 am |
Thanks PCMProgrammer!
So how come this is not listed as a feature that was corrected in later versions on the changes page here: http://www.ccsinfo.com/versions.shtml ?
Do you know what version this was corrected in, if any at all? |
Posted: Fri Feb 17, 2006 10:12 am |
| russr wrote: | Thanks PCMProgrammer!
Unfortunately, the list is about as comprehensive, as a three page telephone directory of the US...
For any single entry on the list, there are typically probably half a dozen other changes, and some (usually ones that perhaps only affect one processor, and were only themselves 'introduced' a version or two ago), never get mentioned.
There were posts here some time ago, about incorrect soft serial baud rates, and these then stopped, so it is presumably fixed. A quick test on a couple of rates for me, seems to give values that are OK, on the current versions.
russr
Posted: Fri Feb 17, 2006 10:16 am |
I emailed their tech support and sent them my .LST file. I think they were able to confirm the problem as they are emailing me the latest version of the compiler.
I only hope the latest version does not introduce additional bugs. |
