Peter-NMB
Joined: 17 Sep 2003 Posts: 11 Location: Glasgow, Scotland
| PIC18F2585 Soft I2C Pin selection Problem |
Posted: Tue Feb 14, 2006 9:01 am |
Hi Hope someone can help,
Using a PIC18F2585 with CCS Version 3.242 Complier,
(Pullups are fitted to Pins being used)
During the implementation of a software version of I2C,
(Using the #USE I2C ...)
I have found that if I select for use Pin B0 and Pin B1 as the SDA or SCL lines, I am unable to Master from the I2C bus and communicate with another device
however, If I choose other Pins B3 to B7, C0 toC7 etc the software I2C functions OK, as long as I do not choose B0 and B1 for the clock or data lines
Why is there a problem in using these two pins for the software I2C functionality?
Posted: Tue Feb 14, 2006 2:10 pm |
Those pins are configured as analog pins upon power-on reset.
CCS puts in start-up code to configure them as digital i/o.
I checked the .LST file for PCM vs. 3.242, and it looks correct.
So I'm not sure what's happening. Can you post a very short
program that demonstrates the problem. I emphasize, SHORT.
Make it be a complete program though, with all #include, #fuses,
#use statements posted. I should be able to copy and paste
it into MPLAB and have it compile OK. Make it SHORT. |
Peter-NMB
Posted: Tue Feb 14, 2006 3:53 pm |
Hi thanks for having a wee look for me,
The program is basically communicating with a battery.
thanks, hopefully it is something stupid that I am doing
I have tried to keep the program short, you should be able to paste it in one go.
#include <18F2585.h>
#device ADC=10
#include <stdlib.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP
#define ON 1
#define OFF 0
// #define SM_DATA PIN_B2 these pins OK
// #define SM_CLK PIN_B3 these pins OK
#define SM_DATA PIN_B0 // these pins NOT OK
#define SM_CLK PIN_B1 // these pins NOT OK
#use I2C(MASTER,SDA=SM_DATA,SCL=SM_CLK,SLOW,SMBUS)
int16 Select_SMBUS(int8 Slave_address,int8 Command_code);
void intI2C();
void Select_Control();
char rxd_byte;
int16 DAC_V=0;
int16 DAC_I=0;
int8 Status=OFF;
//serial comms interrupt
#INT_RDA
serial_isr()
rxd_byte=toupper(getch());
Select_Control();
main()
int16 ADC_Val,From_Battery[5];
signed int16 From_Battery_Curr;
setup_oscillator( OSC_4MHZ);
SET_TRIS_A(0xFF); // configure PortA A2 digital out, A4 digital in
SETUP_ADC_PORTS(ALL_ANALOG|VSS_VREF);
output_low(PIN_B5);
output_high(PIN_B4);
enable_interrupts(int_rda);
Status=OFF;
do
if(Status!=OFF)
output_low(PIN_B5);
output_low(PIN_B4);
output_high(PIN_B5);
intI2C();
From_Battery[2]=Select_SMBUS(0x0B,0x09);
From_Battery_Curr=Select_SMBUS(0x0B,0x0A);
From_Battery[3]=Select_SMBUS(0x0B,0x0E);
From_Battery[1]=Select_SMBUS(0x0B,0x14);
From_Battery[0]=Select_SMBUS(0x0B,0x15);
printf("Chrg Volt :%lu mV\n\r",From_Battery[0]);
printf("Chrg Curr :%lu mA\n\r",From_Battery[1]);
printf("*****Battery Readings*****\n\r");
printf("Batt Volt : %lu mV\n\r",From_Battery[2]);
printf("Batt Curr : %ld mA\n\r",From_Battery_Curr);
printf("State Chrg : %lu percent\n\r",From_Battery[3]);
switch (rxd_byte)
case '1': //off
DAC_V=0;
DAC_I=0;
Status=OFF;
rxd_byte=0;
case '2': // ON
Status=ON;
rxd_byte=0;
default:
DAC_V=0;
DAC_I=0;
Status=OFF;
rxd_byte=0;
void intI2C()
output_float(SM_DATA);
output_float(SM_CLK);
int8 hi,lo;
I2C_start();
I2C_Write(Slave_address<<1);
I2C_Write(Command_code);
I2C_start();
I2C_Write((Slave_address<<1)+1);
lo =I2C_Read(1); // with ack
hi= I2C_Read(0); // with nack
I2C_Stop();
return make16(hi,lo);
Posted: Tue Feb 14, 2006 4:05 pm |
The code doesn't compile. It gets an error on the "do {" statement.
It's expecting a "}while();".
Maybe you just left out a brace, but I want to be sure about it
Can you just edit your previous post and fix the problem ?
Also, test the edited code on your hardware to be sure that it
still shows the problem. Make a short post to let me know
when you've done this. |
Peter-NMB
Posted: Tue Feb 14, 2006 4:29 pm |
Hi PCM Programmer,
I have edited the code, sorry about that, you were correct I had omitted a closing brace, it's now been placed in, within the edited code
I am currently unable to test the code within the hardware at this moment as I am at home. |
Posted: Tue Feb 14, 2006 10:59 pm |
This line is causing the problem:
| Quote: | | SETUP_ADC_PORTS(ALL_ANALOG|VSS_VREF); |
The 18F2585 has analog pins on Port B, not just Port A.
You need to change that line so it excludes those pins on Port B
that you want to use for digital i/o.
Look in the 18F2585.H file, near the end, at this section:
"Constants used in SETUP_ADC_PORTS()"
Next to each constant, CCS has placed a list of the pins that
will be configured as analog if you use the constant.
Pick the appropriate one and use it instead of "ALL_ANALOG". |
Peter-NMB
Posted: Wed Feb 15, 2006 3:09 am |
Hi PCM Programmer,
thanks for that, I should have noticed it
I had been using the pin out for the PIC18F258
RB0/INT0 and RB1/INT1
where as you have correctly stated, the PIC18F2585 has the additional functionality of analog pins on PortB
RB0/INT0/AN10 and RB1/INT1/AN8
thanks for the help, its good to have a fresh set of eyes  |
