using eeprom on 18f1320
alfonsol
PostPosted: Fri Feb 03, 2006 3:43 pm     Reply with quote
How i can save to the eeprom a value longer than 8 bits?
i'm using wrtite_eeprom. if i write 150 it returns 150, but if i write 330 it returns 74.
PostPosted: Fri Feb 03, 2006 3:46 pm     Reply with quote
You write the two bytes seperately. Make8, to get the two bytes, and then use 'make16', to put them back together again when you read.
