		| View previous topic :: View next topic   |
			The Puma
  Joined: 23 Apr 2004 Posts: 227 Location: The Netherlands
				| Need a sample code to drive a SAA1064 |
				 Posted: Wed Jan 11, 2006 12:50 pm     |
				Did anybody has a library for this chip
and some sample code
Maybe for driving four 7 segment displays
( counting from 1 to 9999 as example) |
			Kenny
				 Posted: Thu Jan 12, 2006 12:59 am     |
				This is what I use. There may be a better way to do it.
HTH
#include <16F876.h>
#use delay(clock=16000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
#use i2c(master,sda=PIN_C4,scl=PIN_C3,FORCE_HW)
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,BROWNOUT
#include "saa1064.h"
int16 count = 0;
   // Display 'On' on display with SAA1064 ADR pin tied to Vee
   send_saa1064_msg(LED_ADDR0,LED_CONTROL,on_);
   send_saa1064_msg(LED_ADDR0,LED_CONTROL,blank_);
   delay_ms(300);
     send_saa1064_num(LED_ADDR0,LED_CONTROL,count);
     if(++count == 10000) count = 0;
saa1064.h
// Driver for SAA1064 i2c to multiplexed four-digit, seven-segment led display
// SAA1064 write addresses set by connecting pin1 (ADR) to different voltages
#define LED_ADDR0       0x70  // ADR to Vee
#define LED_ADDR1       0x72  // ADR to 3/8 Vcc
#define LED_ADDR2       0x74  // ADR to 5/8 Vcc
#define LED_ADDR3       0x76  // ADR to Vcc
// Control bits
// C0 = 0 = static mode  C0 = 1 dynamic mode
// C1 = 0/1 digits 1 and 3 are blanked/not blanked
// C2 = 0/1 digits 2 and 4 are blanked/not blanked
// C3 = 1 all segments outputs turned on for segment test
// C4 = 1 adds 3ma to segment output
// C5 = 1 adds 6ma to segment output
// C6 = 1 adds 12ma to segment output
// C7 n/a
#define LED_CONTROL 0x27   //Dynamic mode 6mA
// Segment table (In hex: d.p.=80,g=40,f=20,e=10,d=08,c=04,b=02,a=01)
byte const seg_table[10]=
{0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; // 0,1,2,3,4,5,6,7,8,9
// Some non-numeric characters
//0x00,0x77,0x7C,0x39,0x5E,0x79,0x71,0x36,0x04,0x38, // blank,A,b,C,d,E,F,H,i,L
//0x54,0x5C,0x73,0x50,0x6B,0x1C,0x6E,0x40,0x08       // n,o,p,r,S,u,y,-,_
// Message examples
byte const blank[4] = {0x00,0x00,0x00,0x00};// Blank display
byte const   err[4] = {0x00,0x79,0x50,0x50}; //  Err
byte const    on[4] = {0x00,0x00,0x3F,0x54}; //   On
byte const   off[4] = {0x00,0x3F,0x71,0x71}; //  OFF
enum {blank_,err_,on_,off_};
// Sends number to four-digit led display via SAA1064  (0 to 9999)
void send_saa1064_num(int8 addr,int8 control,int16 num)
   int8 j;                       // Digit index
   int8 led_data[4];     // Ram array for segment data
   int16 temp16;
   // Get led segments for all four digits. Don't need to divide to get units.
   temp16 = num;
   j = 0;
   while (j <= 3)
       if (j != 0) temp16 /= 10;
       led_data[j] = seg_table[temp16 %10];
       j++;
   // Do leading zero blanking
   if (num<1000) led_data[3] = 0x00;
   if (num<100)  led_data[2] = 0x00;
   if (num<10)   led_data[1] = 0x00;
   // Add decimal point if required
   //led_data[2] |= 0x80;
   // Send led segments
   i2c_start();
   i2c_write(addr);        // Send SAA1064 address
   i2c_write(0x00);        // Send instruction byte. Zero is control reg.
   i2c_write(control);     // Send control byte
   // Auto increment applies for digit data. Have to send out digits in reverse
   // because most significant digit is 1st digit.
   for (j=4;j>=1;j--)
      i2c_write(led_data[j-1] & 0xff);
   i2c_stop();
//Sends message to led display via SAA1064
void send_saa1064_msg(int8 addr,int8 control,int8 msg)
   int8 j;
   int8 led_data[4]; // Ram array for segments
   // Get segments for message.
   switch (msg)
      case blank_:
         for(j=0;j<=3;j++)
         led_data[j] = blank[j];
      case err_:
         for(j=0;j<=3;j++)
         led_data[j] = err[j];
      case on_:
         for(j=0;j<=3;j++)
         led_data[j] = on[j];
      case off_:
         for(j=0;j<=3;j++)
         led_data[j] = off[j];
      default:
      for(j=0;j<=3;j++)
   i2c_start();
   for (j=0;j<=3;j++)
      i2c_write(led_data[j]);
   i2c_stop();
			The Puma
				 Posted: Thu Jan 12, 2006 3:59 am     |
				| Thanks, that was what i need |
			JohnLeung
				| Driving 4 7-segment by PIC itself |
				 Posted: Sun Jan 15, 2006 10:21 am     |
				Hi [spam]
Since you've already got the SAA1064 code, please regard this information as a reference only. I have done similar project in the past, however, since SAA1064 was too difficult to get in my country, so I have tried hard to find alternatives and finally, I am using the PIC itself to do the following:
1. drive  9 7-segment displays by a single PIC 16F877a.
2. Provide DING DONG alert audible tone.
3. Receive and transmit RS232 message to-and-from an operator console.
Please look at the CCS Code library section or take a look at my web page at www.emed-technologies.com. I have put all schematics and source code in there under the PIC section.
John |
			The Puma
				 Posted: Sun Jan 15, 2006 10:25 am     |
				Thanks JohnLeung
I have seen it |
			The Puma
				 Posted: Sun Jan 29, 2006 3:17 pm     |
				How can i change that routine to display on the first 2 segments the seconds and on the last 2 segment the minutes of a pcf8583
void Gettime ()
 std  = read_rtc(0x04)&0x3F;  // Stunden vom PCF8583 werden gelesen
 min = read_rtc(0x03);        // Minuten vom PCF8583 werden gelesen
 sek = read_rtc(0x02);        // Sekunden vom PCF8583 werden gelesen
 zeit[0]=hexd2decD(sek);      // Die aktuellen Sekunden werden in den Array gespeichert
 zeit[1]=hexd2decD(min);      // Die aktuellen Minuten werden in den Array gespeichert
 zeit[2]=hexd2decD(std);      // Die aktuellen Stunden werden in den Array gespeichert
