4" 7-segment LED display in 3-digit with 2x7W amplifier
JohnLeung
PostPosted: Thu Jan 12, 2006 4:42 am     Reply with quote
Dear Sirs
A highly recommended book for embedded C programmers :
Embedded System Building Blocks, Complete and Ready-to-use Modules in C, by Jean J. Labrosse.
I have modified one of the chapters on 7-segment LED display for CCS PICC. Very good performance result with my module being able to communicate with a PC, with DING DONG alert tone (have built-in 7W amplifier), and multiplex feature for 1-digit to max. 15 digits from a single mcu 16F877 @ 20MHz!
Interested parties can download the whole project under www.TechToys.com.hk
John
*   This is a demonstration for PIC16-LEDSTK1 by TechToys (www.TechToys.com.hk)
*   Original :
*   Used in an automatic queuing system for a spam
*   Intended for showing queue number in 6 groups (3-digit per group)
*   Now       :
*   Modified for PIC16-LEDSTK1 in 3-digit format
*   Interrupt tasks:
   a) #INT_TIMER0, for multiplexing the LED display
   b) #INT_RDA, for command / data receive
   c) #INT_TBE, for command / data ack
*   DisplayManager() is the only function to decode a string/command from a remote PC and
*   ouptut the string to LED display board. DisplayManager() should be inside TMR1 interrupt
*   routine because BeepManager() is using a simple delay_us() function,
*   which can "jam" the main loop. If DisplayManager() was running in main() loop, a frequent
*   data sequence from PC could overflow the UART receive buffer easily.
*   Packet Protocol:
*   |  '0'  |  '1'  |  '2'  |reserve byte|reserve byte| 0x0d |
*   The length of a complete message is dependent on variables DataBuf[6] array
*   declared under DisplayManager(void).
*   For example, we want to display 3-digit '0' '1' '2' on the LEDs, we need to write
*   ASCII characters '0' '1' '2' 'reserve byte' 'reserve byte' 0x0d to PIC16-LEDSTK1
*   Reserve byte can be used for future expansion, or checksum, etc.
*   It is easy to modify DisplayManager(void) for display > 3 digits
*   Adjust the TMR0 rate for different brightness or change the R2 resistor value onboard
*   Hardware :       PCB 11OCT2004.001
*   Software :       main1.c, demonstration program for PIC16-LEDSTK1
*   Created by :    John Leung (www.TechToys.com.hk)
*   Date:          22th Dec 2004 (Version 1.0)
*   History      :   modified for PIC16-LEDSTK1 dated 12 Jan 2006
#include <16F877a.h>               // register definition file for PIC16F877a
#fuses HS,NOWDT,NOLVP,PUT            // a Microchip PIC16F877
#priority rda, timer1, timer0         // define a priority over the interrupt source
#use delay(clock=20000000)
#include "OS_CPU.h"   //typedef compatible with uCOS-II, specified to CCS PICC
#include "USART.h"   //USART with serial 232 I/O buffer
#include "USART.c"
#include "LED.h"   //LED driver header
#include "LED.c"   //LED driver
#include "BEEP.c"   //For DINGDONG generation via PORTC.2, modified from CCS driver
INT8U    BeepCtr=0;
*****************************     Function Prototypes               ****************************
void DisplayManager(void);
void BeepManager(void);
********************              Interrupt handlers *******************************************
#int_rda
void rda_isr(void)         //Receive command from remote console
   serial_rx_isr();
#int_tbe
void tbe_isr(void)         //Send Command (optional) to remote console for ack
   serial_tx_isr();
#int_TIMER0
void TIMER0_isr(void)
   set_timer0(178);       //reset for ~2ms overflow with prescaler 128, 20MHz clock
   DispMuxHandler();
#int_TIMER1
void TIMER1_isr(void)
   DisplayManager();
****************************************     MAIN     *******************************************
   output_low(PIN_B7);                     //disable power amplifier
   set_adc_channel(NO_ANALOGS);            //Since PortA & PortE has been used for digit select
   enable_interrupts(int_rda);               //enable USART RX
   DispInit();                           //Initialize 7-seg LED
     setup_counters(RTCC_INTERNAL, RTCC_DIV_128);//Adjust timer0 for multiplexing the display
   enable_interrupts(INT_TIMER0);            //Enable tmr0 interrupt
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);      //setup timer1 for character receive and display
   enable_interrupts(global);
   for(;;) {
      BeepManager();                     //output DING DONG via TDA8944 ampifier onboard
**************************************** Sub-routine *****************************************
   INT8U  c;
   INT8U s[DISP_N_SS];      //Data received for display, DISP_N_SS=3 for PIC16-LEDSTK1 demo
   INT8U crx;
   INT8U DataBuf[6];      //data buffer for serial_rx_isr()
   if (EndOfMsg_Flg==TRUE)         //Some character in RX_Buffer
      crx = 0;
      c = bgetc();
      while (c!= EndOfMsg){
         DataBuf[crx++] = c;
         c = bgetc();
      EndOfMsg_Flg = FALSE;
      s[0]=DataBuf[0];s[1]=DataBuf[1];s[2]=DataBuf[2];
      DispStr(0,s);      //output to LED display board
      BeepCtr++;         //output an alert tone "DING DONG"
      bputc('*');         //Acknowledge the PC for a successful message
}//DisplayManager()
      if (BeepCtr>0){                     //BeepCtr increment on every valid call
         BeepCtr--;                     //BeepCtr++ in DisplayManager()
         output_high(PIN_B7);            //ON amplifier
         delay_us(500);                  //For stablize the amplifier
         generate_tone(585, 600);         //DING
         generate_tone(465, 900);         //DONG
         output_low(PIN_B7);               //OFF amplifier
}//BeepManager()
*                                     Multiplexed LED Display Driver
*                   Reference: Jean J. Labrosse, Embedded Systems Building Blocks
* Filename   : LED.h
* Programmer : John Leung (www.TechToys.com.hk)
* Remarks    : Modified for PIC16-LEDSTK1
* Date       : First version 1.0 on 19th Nov 2004
* Language    : CCS C complier for PIC mid-range MCU, PCM version 3.170, under MPLAB IDE 7.01
* Hardware   : PCB 11OCT2004.001, MCU is Microchip's PIC16F877a
* History    : Modified for PIC16-LEDSTK1 dated 12 Jan 2006
*                                              DESCRIPTION
* This module provides an interface to a multiplexed "7-segments x N digits" LED matrix.
* To use this driver:
*     1) To use this module, the following parameters under define (LED.H):
*        DISP_N_DIG          The total number of segments to display, inc. dp status
*        DISP_N_SS           The total number of seven-segment digits, e.g "0" "1" "2" is 3-digit
*        DISP_PORT1_DIG      The address of the DIGITS   output port
*        DISP_PORT_SEG       The address of the SEGMENTS output port
*       first_dig_msk       The first digit mask for selecting the most significant digit
*     2) Allocate a hardware timer which will interrupt the CPU at a rate of at least:
*        DISP_N_DIG * 60  (Hz)
*                                               CONSTANTS
//Assume a PIC 16F877a MCU
//Using PORTA & PORTE for dig select, make sure it is set as digital
#byte  DISP_PORT1_DIG =  0x05  /* Port address of DIGITS output for the 1st and 2nd group (PORTA)   */
#byte  DISP_PORT2_DIG =  0x09  /* Port address of DIGITS output for the 3rd group (PORTE)           */
#byte  DISP_PORT_SEG  =  0x08  /* Port address of SEGMENTS output (PORTD)                      */
#define set_tris_seg(x)    set_tris_d(x)      /*Set segment port                              */
#define set_tris1_dig(x) set_tris_a(x)      /*Set digit select port                           */
#define set_tris2_dig(x) set_tris_e(x)      /*Set digit select port                           */
#define  DISP_N_DIG          8         /* Total number of segments (including dp indicators)       */
#define  DISP_N_SS           3         /* Total number of seven-segment digits (PORTA) of F877      */
#define    first_dig_msk      0b000000100   /* First seven-segment digit mask                     */
//remarks: There is no typo error on first_dig_msk. It is a 9-bits constant because the hardware
//allows extension to 9-digits multiplexing. Actually, if we are using PORT RB as well,
//we can extend to a maximum of 15 digits!
*                   User define if hardware is Common Anode or Cathode
*    The application should define if the hardware is a COMMON ANODE or CATHODE
#define ALL_OFF 0x00
#define ALL_ON ~ALL_OFF
*                                          FUNCTION PROTOTYPES
void  DispClrScr(void);               //API to clear the display
void  DispInit(void);               //API to initialize the display, call before using other functions
void  DispMuxHandler(void);            //called by the hardware timer at a rate of at least DISP_N_DIG*60 (Hz)
void  DispStr(INT8U dig, char *s);      //API to display an ASCII string
void  DispStatClr(INT8U dig, INT8U seg);//API to turn off a single LED
*   dig specifies the digit
*   seg specfiies segment to set as follows
*   0 sets segment dp (bit0)
*   1 sets segment g (bit1)
*   2 sets segment f (bit2)
*   3 sets segment e (bit3)
*   4 sets segment d (bit4)
*   5 sets segment c (bit5)
*   6 sets segment b (bit6)
*   7 sets segment a (bit7)
void  DispStatSet(INT8U dig, INT8U seg);   //API to turn on a single LED
*                                           HARDWARE SPECIFIC
void  DispInitPort(void);         //called by DispInit() to initialize the output ports
void  DispOutDig(INT16U msk);      //digit selector
void  DispOutSeg(INT8U seg);      //output seven-segment patterns
* Filename   : LED.C
*                                              DESCRIPTION
*        DISP_N_SS           The total number of seven-segment digits (modules)
*                                            LOCAL VARIABLES
//Remarks: The original Jean's code uses static for local variables; however, this is not valid
//for CCS PICC complier as "static" has no effect under CCS C.
static   INT16U DispDigMsk;            /* Bit mask used to point to next digit to display  */
static   INT8U  DispSegTbl[DISP_N_SS]; /* Segment pattern table(buffer) for each digit to display, first entry the left most*/
static   INT8U  DispSegTblIx;         /* Index into DispSegTbl[] for next digit to display */
/*$PAGE*/
*                             ASCII to SEVEN-SEGMENT conversion table
*                                                             a
*                                                        f |      | b
*                                                          |  g   |
* Note: The segments are mapped as follows:                 ------
*                                                        e |      | c
*        a    b    c    d    e    f    g                   |  d   |
*        D7   D6   D5   D4   D3   D2   D1   D0 (Using PORTD of 16F877a as the segments output port)
const INT8U DispASCIItoSegTbl[] = {// ASCII to SEVEN-SEGMENT conversion table
    0x00,       // ' '
    0x00,       // '!', No seven-segment conversion for exclamation point
    0x44,       // '"', Double quote
    0x00,       // '#', Pound sign
    0x00,       // '$', No seven-segment conversion for dollar sign
    0x00,       // '%', No seven-segment conversion for percent sign
    0x00,       // '&', No seven-segment conversion for ampersand
    0x40,       // ''', Single quote
    0x9C,       // '(', Same as '['
    0xF0,       // ')', Same as ']'
    0x00,       // '*', No seven-segment conversion for asterix
    0x00,       // '+', No seven-segment conversion for plus sign
    0x00,       // ',', No seven-segment conversion for comma
    0x02,       // '-', Minus sign
    0x00,       // '.', No seven-segment conversion for period
    0x00,       // '/', No seven-segment conversion for slash
    0xFC,       // '0'
    0x60,       // '1'
    0xDA,       // '2'
    0xF2,       // '3'
    0x66,       // '4'
    0xB6,       // '5'
    0xBE,       // '6'
    0xE0,       // '7'
    0xFE,       // '8'
    0xF6,       // '9'
    0x00,       // ':', No seven-segment conversion for colon
    0x00,       // ';', No seven-segment conversion for semi-colon
    0x00,       // '<', No seven-segment conversion for less-than sign
    0x12,       // '=', Equal sign
    0x00,       // '>', No seven-segment conversion for greater-than sign
    0xCA,       //'?', Question mark
    0x00,       // '@', No seven-segment conversion for commercial at-sign
    0xEE,       // 'A'
    0x3E,       // 'B', Actually displayed as 'b'
    0x9C,       // 'C'
    0x7A,       // 'D', Actually displayed as 'd'
    0x9E,       // 'E'
    0x8E,       // 'F'
    0xBC,       // 'G', Actually displayed as 'g'
    0x6E,       // 'H'
    0x60,       // 'I', Same as '1'
    0x78,       // 'J'
    0x00,       // 'K', No seven-segment conversion
    0x1C,       // 'L'
    0x00,       // 'M', No seven-segment conversion
    0x2A,       // 'N', Actually displayed as 'n'
    0xFC,       // 'O', Same as '0'
    0xCE,       // 'P'
    0x00,       // 'Q', No seven-segment conversion
    0x0A,       // 'R', Actually displayed as 'r'
    0xB6,       // 'S', Same as '5'
    0x1E,       // 'T', Actually displayed as 't'
    0x7C,       // 'U'
    0x00,       // 'V', No seven-segment conversion
    0x00,       // 'W', No seven-segment conversion
    0x00,       // 'X', No seven-segment conversion
    0x76,       // 'Y'
    0x00,       // 'Z', No seven-segment conversion
    0x00,       // '['
    0x00,       // '\', No seven-segment conversion
    0x00,       // ']'
    0x00,       // '^', No seven-segment conversion
    0x00,       // '_', Underscore
    0x00,       // '`', No seven-segment conversion for reverse quote
    0xFA,       // 'a'
    0x3E,       // 'b'
    0x1A,       // 'c'
    0x7A,       // 'd'
    0xDE,       // 'e'
    0x8E,       // 'f', Actually displayed as 'F'
    0xBC,       // 'g'
    0x2E,       // 'h'
    0x20,       // 'i'
    0x78,       // 'j', Actually displayed as 'J'
    0x00,       // 'k', No seven-segment conversion
    0x1C,       // 'l', Actually displayed as 'L'
    0x00,       // 'm', No seven-segment conversion
    0x2A,       // 'n'
    0x3A,       // 'o'
    0xCE,       // 'p', Actually displayed as 'P'
    0x00,       // 'q', No seven-segment conversion
    0x0A,       // 'r'
    0xB6,       // 's', Actually displayed as 'S'
    0x1E,       // 't'
    0x38,    // 'u'
    0x00,    // 'v', No seven-segment conversion
    0x00,    // 'w', No seven-segment conversion
    0x00,    // 'x', No seven-segment conversion
    0x76,    // 'y', Actually displayed as 'Y'
    0x00     // 'z', No seven-segment conversion
*                                          CLEAR THE DISPLAY
* Description: This function is called to clear the display.
* Arguments  : none
* Returns    : none
void  DispClrScr (void)
    INT8U i;
    for (i = 0; i < DISP_N_SS; i++) {    /* Zero the buffer */
        DispSegTbl[i] = ALL_OFF;
*                                      DISPLAY DRIVER INITIALIZATION
* Description : This function initializes the display driver.
* Arguments   : None.
* Returns     : None.
void  DispInit (void)
    DispInitPort();                 // Initialize I/O ports used in display driver
    DispDigMsk   = first_dig_msk;   // digit mask starts from RAx
    DispSegTblIx = 0;
    DispClrScr();                   // Clear the Display
*                                        DISPLAY NEXT SEVEN-SEGMENT DIGIT
* Description: Called by an interrupt handler to output the segments and select the next digit
*              to be multiplexed.
* Arguments  : none
* Returns    : none
* Notes      :
void  DispMuxHandler (void)
                                                 /* Insert code to CLEAR INTERRUPT SOURCE here         */
    DispOutSeg(ALL_OFF);                         /* Turn OFF segments while changing digits            */
    DispOutDig(DispDigMsk);                      /* Select next digit to display                       */
    DispOutSeg(DispSegTbl[DispSegTblIx]);        /* Output digit's seven-segment pattern               */
    if (DispSegTblIx == (DISP_N_SS - 1)) {       /* Adjust index to next seven-segment pattern         */
        DispSegTblIx =    0;                     /* Index into first segments pattern                  */
        DispDigMsk   = first_dig_msk;            /* Select the most significant digit  */
    } else {
        DispSegTblIx++;
        DispDigMsk >>= 1;                        /* Select next digit                                  */
*                                         CLEAR STATUS SEGMENT
* Description: This function is called to turn OFF a single segment on the display.
* Arguments  : dig   is the position of the digit where the segment appears (0..DISP_N_DIG-1)
*              seg   is the segment bit to turn OFF (0..7)
* Returns    : none
void  DispStatClr (INT8U dig, INT8U seg)
    DispSegTbl[dig] &= ~(1 << seg);
*                                           SET STATUS SEGMENT
* Description: This function is called to turn ON a single segment on the display.
*              seg   is the segment bit to turn ON (0..7)
* Returns    : none
void  DispStatSet (INT8U dig, INT8U seg)
    DispSegTbl[dig] |= 1 <<seg;
/*$PAGE*/
*                            DISPLAY ASCII STRING ON SEVEN-SEGMENT DISPLAY
* Description: This function is called to display an ASCII string on the seven-segment display.
* Arguments  : dig   is the position of the first digit where the string will appear:
*                        0 for the first  seven-segment digit.
*                        1 for the second seven-segment digit.
*                        DISP_N_SS - 1 is the last seven-segment digit.
*              s     is the ASCII string to display
* Returns    : none
* Notes      : - Not all ASCII characters can be displayed on a seven-segment display.  Consult the
*                ASCII to seven-segment conversion table DispASCIItoSegTbl[].
void  DispStr (INT8U dig, unsigned char *s)
    while (*s && dig < DISP_N_SS) {
        DispSegTbl[dig++] = DispASCIItoSegTbl[*s++ - 0x20];
*                                        I/O PORTS INITIALIZATION
* Description: Called by DispInit() to initialize the output ports used in the LED multiplexing.
* Arguments  : none
* Returns    : none
* Notes      :
void  DispInitPort (void)
   DISP_PORT_SEG=ALL_OFF;         //Turn off segments
   DISP_PORT1_DIG=0x00;         //Turn off the 1st and 2nd groups (first group uses RA0,A1,A2, 2nd group
                           //      uses RA3,A4,A5)
   DISP_PORT2_DIG=0x00;         //Turn off the 3rd group (3rd group uses RE0,E1,E2)
   set_tris_seg(0x00);            //Set segment port an output
   set_tris1_dig(0x00);         //Set digit port an output
   set_tris2_dig(0x00);
*                                        DIGIT output
* Description: This function outputs the digit selector.
* Arguments  : msk    is the mask used to select the current digit.
* Returns    : none
void  DispOutDig (INT16U msk)
    DISP_PORT1_DIG=msk;   //digit selector here
   DISP_PORT2_DIG=msk>>6;
*                                        SEGMENTS output
* Description: This function outputs seven-segment patterns.
* Arguments  : seg    is the seven-segment pattern to output
* Returns    : none
void  DispOutSeg (INT8U seg)
   DISP_PORT_SEG=seg;   //output seven-segment pattern
*                    Interrupt Driven Transmit (Tx) and Receive (Rx) modules
*      Reference: Embedded C Programming and the Microchip PIC by Barnett, Cox, & O'Cull
* Filename   : USART.h
* Date       : 19th Nov 2004
/* Use dialect of CCS PIC complier, assume a PIC with USART Port (16F877a etc)*/
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=RS232,bits=8)
#define  RX_BUFFER_SIZE        32      // UART Receive buffer
#define  TX_BUFFER_SIZE        5      // UART Transmit buffer
#define    EndOfMsg            0x0d      // <cr> as the end of command marker
void    serial_rx_isr(void);    //ISR handler for Rx
INT8U    bgetc(void);         //Get a character from the UART Receiver buffer
void    serial_tx_isr(void);    //USART Transmitter interrupt service routine
void    bputc(INT8U c);       //Write a character to the serial transmit buffer
void    CommRxFlush(void);       //flush any input characters still in the UART Receiver buffer
* Filename   : USART.c
* Date       : 15th June 2004
INT8U Rx_Buffer[RX_BUFFER_SIZE+1];       // character array (buffer)
INT8U RX_Wr_Index = 0;                // index of next char to be put into the buffer
INT8U RX_Rd_Index = 0;                // index of next char to be fetched from the buffer
INT8U RX_Counter = 0;                 // total count of characters in the buffer
BOOLEAN  RX_Buffer_Overflow = FALSE;      // this flag is set on UART Receiver buffer overflow
BOOLEAN EndOfMsg_Flg = FALSE;         // End-of-Message flag to indicate EndOfMsg has been received
INT8U TX_Buffer [TX_BUFFER_SIZE+1];    // character array (buffer)
INT8U TX_Rd_Index = 0;                // index of next char to be put into the buffer
INT8U TX_Wr_Index = 0;                // index of next char to be fetched from the buffer
INT8U TX_Counter = 0;                // total count of characters in the buffer
// USART Receiver interrupt service routine, slightly modified according to Jean J. Labrosse's routine
void serial_rx_isr()
   if(++RX_Counter <= RX_BUFFER_SIZE)       //if Rx Ring buffer not full, and keep character count
        Rx_Buffer[RX_Wr_Index] = getc();     // put received char in buffer
      if(Rx_Buffer[RX_Wr_Index] == EndOfMsg) //set EndOfMsg_Flg for command process
         EndOfMsg_Flg=TRUE;
       if(++RX_Wr_Index > RX_BUFFER_SIZE)    // wrap the pointer
           RX_Wr_Index = 0;
   } else {
      RX_Counter = RX_BUFFER_SIZE;       // if too many chars came
       RX_Buffer_Overflow = TRUE;         // in before they could be used, that could cause an error
// Get a single character from the UART Receiver buffer
INT8U bgetc(void)
   INT8U c;
   while(RX_Counter == 0)      // wait for a character...
   c = Rx_Buffer[RX_Rd_Index];    // get one (first) from the buffer..
    if(++RX_Rd_Index > RX_BUFFER_SIZE) // wrap the pointer
        RX_Rd_Index = 0;
   if(RX_Counter)
      RX_Counter--;        // keep a count (buffer size)
   return c;
// USART Transmitter interrupt service routine
void serial_tx_isr()
      //if there are characters to be transmitted....
      if(TX_Counter != 0)
         putc(TX_Buffer[TX_Rd_Index]);
         // send char out port
         // test and wrap the pointer
         if(++TX_Rd_Index > TX_BUFFER_SIZE)
            TX_Rd_Index = 0;
        TX_Counter--;   // keep track of the counter
        if (TX_Counter == 0)
             disable_interrupts(int_tbe);
// write a character to the serial transmit buffer
void bputc(INT8U c)
    INT8U restart = 0;
    while(TX_Counter > (TX_BUFFER_SIZE-1))
         ;       // WAIT!! Buffer is getting full!!
    if(TX_Counter == 0) // if buffer empty, setup for interrupt
       restart = 1;
    TX_Buffer[TX_Wr_Index++]=c; // jam the char in the buffer..
    if(TX_Wr_Index > TX_BUFFER_SIZE)     // wrap the pointer
        TX_Wr_Index = 0;
                            // keep track of buffered chars
    TX_Counter++;
    // do we have to "Prime the pump"?
    if(restart == 1)
        enable_interrupts(int_tbe);
//This function flushes any input characters still in the RX UART buffer
//This must be called whenever RX_Buffer_Overflow = TRUE
   disable_interrupts(int_rda);   //disable USART Rx interrupt
   //reset all Rx indexes and counters
   RX_Wr_Index = 0;
   RX_Rd_Index = 0;
   RX_Counter = 0;
   #ifdef EoM
*                                    CCS PICC Complier Specific Code
* File : OS_CPU.H
* By   : John Leung for CCS PICC complier for low & mid - range CPUs
*                                              DATA TYPES
*                               (Compiler Specific, CCS PICC in this case)
typedef unsigned char        INT8U;                    /* Unsigned  8 bit quantity */
typedef signed   char        INT8S;                    /* Signed    8 bit quantity */
typedef unsigned long int   INT16U;                   /* Unsigned 16 bit quantity */
typedef long int         INT16S;                   /* Signed   16 bit quantity */
typedef unsigned int32     INT32U;                   /* Unsigned 32 bit quantity */
typedef signed int32        INT32S;                   /* Signed   32 bit quantity */
typedef float                FP32;                     /* Single precision floating point */
////////////////// Driver to generate musical tones /////////////////////
////  generate_tone(frequency, duration)     Generates wave at set   ////
////                                         frequency (Hz) for set  ////
////                                         duration (ms)           ////
////        (C) Copyright 1996,2003 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#ifndef  MUSIC_NOTES
#define  MUSIC_NOTES
//            NOTE                 FREQUENCY
//                     Octave0  Octave1  Octave2  Octave3
const long C_NOTE[4]  ={ 262,     523,    1047,    2093};
const long Db_NOTE[4] ={ 277,     554,    1109,    2217};
const long D_NOTE[4]  ={ 294,     587,    1175,    2349};
const long Eb_NOTE[4] ={ 311,     622,    1245,    2489};
const long E_NOTE[4]  ={ 330,     659,    1329,    2637};
const long F_NOTE[4]  ={ 349,     698,    1397,    2794};
const long Gb_NOTE[4] ={ 370,     740,    1480,    2960};
const long G_NOTE[4]  ={ 392,     784,    1568,    3136};
const long Ab_NOTE[4] ={ 415,     831,    1661,    3322};
const long A_NOTE[4]  ={ 440,     880,    1760,    3520};
const long Bb_NOTE[4] ={ 466,     923,    1865,    3729};
const long B_NOTE[4]  ={ 494,     988,    1976,    3951};
#define TONE_PIN  PIN_C2
void do_delay(int ms_delay, int num_ms, int us_delay, int num_us)  {
 int i;
 for(i=0;i<num_ms;i++)
  delay_ms(250);
 delay_ms(ms_delay);
 for(i=0;i<num_us;i++)
  delay_us(250);
 delay_us(us_delay);
void generate_tone(long frequency, long duration)
   int32 total_delay_time;                      // in microseconds
   long total_ms_delay_time, total_us_delay_time;
   int num_us_delays, num_ms_delays, ms_delay_time, us_delay_time;
   long num_periods;
   total_delay_time = (1000000/frequency)/2-10; // calculate total delay time (10 for error)
   total_ms_delay_time = total_delay_time/1000; // total delay time of ms
   num_ms_delays = total_ms_delay_time/250;     // number of 250ms delays needed
   ms_delay_time = total_ms_delay_time%250;     // left over ms delay time needed
   total_us_delay_time = total_delay_time%1000; // total delay time of us (ms already acounted for)
   num_us_delays = total_us_delay_time/250;     // number of 250us delays needed
   us_delay_time = total_us_delay_time%250;     // left over us delay time needed
   num_periods = ((int32)duration*1000)/(1000000/frequency);
   while((num_periods--) != 0)
      do_delay(ms_delay_time, num_ms_delays, us_delay_time, num_us_delays);
      output_high(TONE_PIN);
      output_low(TONE_PIN);
   return;
