Creating a string table...
LTS
PostPosted: Wed Dec 21, 2005 1:59 pm     Reply with quote
Hello
I want to store several strings in a table. This is for displaying "info" screens on a graphic lcd.
I have no problem displaying
char info[]="Hello, this is the info screen";
glcd_putc(info);
I want to declare something like:
char info[][x]="skjdkhfs","sijdfhskd","jskdhfk";
And be able to to do f.ex
glcd_putc(info[1]);
glcd_putc(info[2]);
and so on..
Tried alot of things, but get tons of errors..
Is it possible to create a table with lets say 10 elements of 50 chars?
Thanks in advance
LT
PostPosted: Wed Dec 21, 2005 2:29 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=25234
This thread has a method of doing what you wish, but in a different way.
LTS
PostPosted: Wed Dec 21, 2005 2:42 pm     Reply with quote
Hmm, ok, i guess i could use that method, but is there no way to create a simple table of strings, and then use simple indexes "info[x]" to reach?
PostPosted: Wed Dec 21, 2005 2:46 pm     Reply with quote
Here is one example. It displays:
ABCD
Hello
Hi there
123456789
#include <16F877.H>
#use delay(clock = 4000000)
#define NUM_STRINGS 4
#define STRING_BUF_SIZE 10
const char array[NUM_STRINGS][STRING_BUF_SIZE] =
{"ABCD"},
{"Hello"},
{"Hi there"},
{"123456789"}
int8 i;
int8 j;
int8 c;
for(i = 0; i < NUM_STRINGS; i++)
    for(j = 0; j < STRING_BUF_SIZE; j++)
        c = array[i][j];
        if(c == 0)  // If reached end of string
           putc(10);  // then display CRLF and break
           putc(13);
          putc(c);
LTS
PostPosted: Wed Dec 21, 2005 2:54 pm     Reply with quote
Great, thats exactly what i meant.. but.. how many elements and how many chars per element can i use? I really need each element to contain between 50-100 chars..
PostPosted: Wed Dec 21, 2005 3:13 pm     Reply with quote
Unfortunately, you can't do it. CCS says this in the manual:
ROM arrays may not occupy more than 256 locations.
So you can't do it with one large two-dimensional const array.
Example:
This compiles OK:
const char array[2][128] =
{"ABCD"},
{"Hello"},
But this gives an error because 2 x 129 = 258, and that's greater than 256.
const char array[2][129] =
{"ABCD"},
{"Hello"},
LTS
PostPosted: Wed Dec 21, 2005 3:20 pm     Reply with quote
Damn... I guess I could use several arrays, but then again I get an indexing problem. What is the best way to store several strings around 100 chars, and easily use an integer to reach the correct one?
PostPosted: Wed Dec 21, 2005 3:38 pm     Reply with quote
Here is one way. The code below displays this:
ABCD
Hello World
The quick brown fox jumps over the lazy dogs back
#include <16F877.H>
const char msg1[] ={"ABCD"};
const char msg2[] ={"Hello World"};
const char msg3[] ={"The quick brown fox jumps over the lazy dogs back"};
void display_msg(int8 index)
switch(index)
   case 1:
      printf(msg1);
   case 2:
      printf(msg2);
   case 3:
      printf(msg3);
printf("\n\r");
display_msg(1);
display_msg(2);
display_msg(3);
LTS
PostPosted: Wed Dec 21, 2005 3:49 pm     Reply with quote
Yeah, that would work. Thanks!
