SPI and 16F687
philk
SPI and 16F687
PostPosted: Fri Dec 02, 2005 5:07 pm     Reply with quote
I am running version 3.238 of the CCS compiler from within MPLAB on a very simple test case of the SPI interface.
#include <16F687.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, NOPUT
#use delay(clock=8000000)
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4);
loop:
   spi_write(0x55);
   delay_us(100);
   goto loop;
When I execute the above via the MPLAB simulator the spi_write function never returns. It continuously loops looking for the Buffer Status Full bit to be set. More importantly the simulator does not show any activity on the SPI pins (PORTB & PORTC).
Is this a "feature" of the simulator?
Is this a "feature" of the compiler?
Thanks for any ideas or suggestions.
Phil
PostPosted: Fri Dec 02, 2005 5:42 pm     Reply with quote
See the Microchip forum:
http://forum.microchip.com/tm.asp?m=107506&mpage=1&key=spi&anchor#109773
http://forum.microchip.com/tm.asp?m=116484&mpage=1&key=spi&anchor#116484
philk
PostPosted: Fri Dec 02, 2005 6:06 pm     Reply with quote
Ah yes, a simulator "feature". Now If I hadn't spent the last couple of hours on this I would be happier....
Thanks,
Phil
