Using R6 and R7 for I/O and Serial UART?
PostPosted: Fri Dec 02, 2005 10:43 am     Reply with quote
I am using the #use rs232 function with the hardware uart on a PIC18F series. However I can't then use output_low(PIN_C7) to drive pin c7 low. I only need to use the rs232 a certain parts of the program. I seem to remember a way to switch the #use directive on/off as required? Can't find it in the manual. Any ideas?
TTelmah
PostPosted: Fri Dec 02, 2005 11:24 am     Reply with quote
I think the easiest for what you describe, would be just to turn the peripheral off. So:
#bit SPEN=0xFAB.7
//Then to use the RS232:
SPEN=TRUE;
printf("TEST");
//Then to set C7 low
SPEN=FALSE;
output_low(PIN_C7);
The problem is that the peripheral enable, overrides the pin's output drive, so though the output is still 'commanded', the peripheal override prevents the pin from being driven.
