o_wan Guest
| Driving DC w/ PWM |
Posted: Tue Nov 22, 2005 2:52 pm |
hi all,
Since my PIC16F877A got 2 PWM only, is that possible to drive DC w/o PWM, can I use generate pulse on & off code to replace PWM like below and w/ h-bridge circuit?
Anyone did that b4?
#include <16f877A.h> /*include standard functions of our PIC chip*/
#fuses XT,NOLVP,NOWDT
void MOVE(int on, int off)
{output_bit(PIN_A2,1); output_bit(PIN_A3,0);}
{output_bit(PIN_A1,1); output_bit(PIN_A0,0);}
delay_ms(on);
{output_bit(PIN_A2,0); output_bit(PIN_A3,0);}
{output_bit(PIN_A1,0); output_bit(PIN_A0,0);}
delay_ms(off);
main(){
int t;
while(1){
for(t=0;t<100;t++) MOVE(3,10);
for(t=0;t<30;t++) MOVE(10,10);
SherpaDoug
Posted: Tue Nov 22, 2005 3:53 pm |
That should work, but I would just set up an XOR mask for port A so I could change all four outputs with a single instruction. You can load the port with a word that shuts off all the switches to let the motor freewheel. You can have another word that grounds both ends of the motor for braking. To run you load a word to start the bridge, and then just XOR that word to run the bridge. _________________ The search for better is endless. Instead simply find very good and get the job done. |
