KenMacfarlane
Joined: 20 Sep 2005 Posts: 23 Location: Glasgow, Scotland, UK
| Time to Write to Internal Eeprom & Flash? |
Posted: Mon Nov 21, 2005 5:11 am |
I want to buffer 20-30 bytes of data arriving every few seconds, to any spare internal eeprom or flash program memory that I've got left , on a 10 MHz Modtronics SB65 (PIC18f6621), in case I loose the serial link to a PC host for a few minutes.
Anybody know how long it takes to read or write using these funcs?
write_eeprom & read_eeprom
write_program_eeprom & read_program_eeprom
write_program_memory & read_program_memory
Neither the CCS help or manual give any idea, but I presume that there is a "write every few hundred microseconds" until it reads back correct going on inside the write routines, and that this might take a few millisecs per byte???? |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Mon Nov 21, 2005 6:27 am |
The CCcode overhead is negligible. The time is dependant on the write characteristics of the device and can be found in the data sheet for the processor. For example, a 18F1320 has an 18ms page write to Flash Program Memory time. The CCS executes the write and waits until it is complete before returning. _________________ Regards, Andrew
