SungYong
| LCD problem / help |
Posted: Tue Nov 15, 2005 12:44 am |
Hello, I want to print sum(type double) on LCD display.
device : 16F874
use 8LINES
LCD 16x2
This is my source code.
| Code: | #include <C:\Program Files\PICC\Devices\16f874.h>
struct lcd_pin_map{
boolean enable; // lcd enable signal
boolean rs; // lcd register select signal
boolean rw; // lcd read/write signal
} lcd_control;
#byte lcd_control = 5
#byte portb = 6
void BusyCheck(){
do{
portb = 0x00;
set_tris_b(0xff);
lcd_control.rs = 0;
delay_cycles(1);
lcd_control.rw = 1;
delay_cycles(1);
lcd_control.enable = 1;
delay_cycles(2);
lcd_control.enable = 0;
} while(bit_test(portb,7));
portb = 0x00;
return;
void SendChar(char bf){
BusyCheck();
set_tris_b(0x00);
portb = bf;
lcd_control.rw = 0;
lcd_control.rs = 1;
delay_cycles(1);
delay_cycles(1);
return;
void SendCmd(char cmd){
BusyCheck();
set_tris_b(0x00);
portb = cmd;
lcd_control.rw = 0;
lcd_control.rs = 0;
delay_cycles(1);
delay_cycles(1);
return;
void lcd_init(){
setup_adc_ports(no_analogs);
set_tris_b(0x00);
set_tris_a(0x00);
lcd_control = 0x00;
portb = 0x00;
portb = 0b00111000;
delay_cycles(1);
delay_cycles(1);
delay_ms(15);
portb = 0b00111000;
delay_cycles(1);
delay_cycles(1);
delay_ms(1);
SendCmd(0b00001110); // disply on/off control
SendCmd(0b00000110); // entry mode set
SendCmd(0b00000001); // clear display
SendCmd(0b00000010); // return home
return;
void gotoxy(int x, int y)
int address;
if(x>=16) x = 0;
if(y!=1)
address = 0x80;
address = 0xc0;
SendCmd(address + x);
void main(){
double sum;
sum = 10000;
while(1){
gotoxy(0,0);
SendChar("MATH SUM");
gotoxy(5,1);
SendChar(sum); <<==== This is my problem :cry: :question:
I know SendChar("10000");
Is there another way to print sum on LCD? |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Tue Nov 15, 2005 12:52 am |
| Code: | void main(){
double sum;
sum = 10000;
while(1){
gotoxy(0,0);
printf(SendChar, "MATH SUM");
gotoxy(5,1);
printf(SendChar, "%d", sum);
_________________ Regards, Andrew
Ttelmah Guest
Posted: Tue Nov 15, 2005 3:49 am |
First, CCS, does not support a 'double' data type. It accepts the keyword, and stores a 4byte float, for this 'type', but this is a bodge to avoid complaints when porting code. Safer to use one of the types that is documented as supported.
Given this variable then holds a float, the printf % statement to display it, should use %f, or %g (to give different rounding behaviour).
Given that you are only holding integers, better to use either an int16, or an int32. The printf format for these is %Ld (not %d, which only handles single 'byte' integers).
SungYong
Posted: Tue Nov 15, 2005 4:20 am |
Thank you so much!!
Now I can print~
Thanks again. |
