C compiled part inside assembler
Fabri
PostPosted: Mon Nov 14, 2005 2:40 am     Reply with quote
Hi everybody,
I have an old project compiled in assembler with MPLAB. Now I want to include a new part compiled in C.
1) Is it Possible ?
2) Is there any example somewere ?
Thanks for support,
Regards,
PostPosted: Mon Nov 14, 2005 6:11 pm     Reply with quote
The CCS compiler doesn't (yet) produce linkable object modules.
You would have to use a different C compiler.
Here is a thread on the Microchip forum on the topic:
http://forum.microchip.com/tm.asp?m=101387&mpage=1&key=asm%2Cmodules&anchor#101420
cwilliams@edge-pdc.com
mixing C and assembler
PostPosted: Tue Dec 13, 2005 2:13 pm     Reply with quote
I'm using CCS PCH v3.214 with MPLAB 7.10 and MPASM etc 3.90.01.
The project was originally written in assembler, and then some floating point stuff was added using C. I have the source but not the tools. My tools (above) won't compile/assemble and link this.
Do I need different tools?
PostPosted: Tue Dec 13, 2005 5:29 pm     Reply with quote
Either get new tools, or convert the ASM code into C.
asmallri
PostPosted: Tue Dec 13, 2005 7:22 pm     Reply with quote
If you have the assembler source code you can use CCS's mini assembler and embedd the code in your C code.
Regards, Andrew
PostPosted: Tue Dec 13, 2005 7:47 pm     Reply with quote
Yes, but people are always complaining that they can't
do everything they want with the CCS inline assembler.
asmallri
PostPosted: Tue Dec 13, 2005 8:12 pm     Reply with quote
On one hand I agree with them. It is a pain that it doesn't , especially not supporting all the FSRs, but on the otherhand its not rocket science to change the affected code.
Regards, Andrew
