leesing2k3
| Simple question about 16F628 RS232 |
Posted: Mon Nov 14, 2005 12:28 am |
I try to use other pins other than B1 and B2 to do RS232 but the data i m receiving is not correct. Izzit possible to use other pins to do RS232 or is there anything i should do to make it possible?
I have declared it correctly.
Thank you. |
asmallri
Joined: 12 Aug 2004 Posts: 1664 Location: Perth, Australia
| Re: Simple question about 16F628 RS232 |
Posted: Mon Nov 14, 2005 12:54 am |
| leesing2k3 wrote: | I try to use other pins other than B1 and B2 to do RS232 but the data i m receiving is not correct. Izzit possible to use other pins to do RS232 or is there anything i should do to make it possible?
Thank you. |
You can use any I/O pins that are free. You have not given any clue as to what your problem is. Without a crystal ball there is nothing else I can suggest. _________________ Regards, Andrew
Posted: Mon Nov 14, 2005 12:57 am |
What pins are you using ?
Try this simple program with a terminal program running on your PC.
This program just returns the same character that was sent to it.
Substitute your pins for B2 and B1. See if it works.
If it doesn't work, then post your version of the compiler.
| Code: | #include <16F628.H>
#use delay(clock = 4000000)
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, ERRORS)
char c;
c = getc();
putc(c);
leesing2k3
Posted: Mon Nov 14, 2005 8:52 am |
| thank you very much |
