		| Author | Message |
		| Jim C Ashby
				| Function Prototyping |
				|  Posted: Wed Nov 09, 2005 10:48 am |   |
				| I just upgraded to the latest Compiler and I started getting errors that all of my function prototype were already defined.
 I // out all of the function prototypes in my main C code, and the error went away.
 Question:  Is it no longer needed to declare function prototype as long as we use the #include command to include the various files which contain the funtions?
		| PCM programmer
				|  Posted: Wed Nov 09, 2005 11:11 am |   |
				|  	  | Quote: |  	  | I just upgraded to the latest Compiler and I started getting errors that all
 Were you typing in function prototypes of the CCS built-in functions?
 You don't need to do that.
 Were you typing in function prototypes of functions that are in the
 various CCS driver files ?
 You don't need to do that, either.   Just #include the driver files above
 main(),  right after all your #use() and other pre-processor statements.
 If this doesn't answer your question, then give more specific details
 about the error messages.
		| Jim C Ashby
				|  Posted: Wed Nov 09, 2005 11:28 am |   |
				| I created my own functions and placed them in my own files. file named menu1100.c containes the funcrion menu_1100() which executes a menu system.
 In my Main.c program I had in the past needed to place a function prototype suach as void menu_1100(); and place #include "menu1100.c" above the prototype all above the main() section of the code.
 Once I upgraded to the lastest version, I received error messages when the void menu_1100(); was in the main.c file.
 I had to remove the function prototyping, all of them.
		| PCM programmer
				|  Posted: Wed Nov 09, 2005 12:26 pm |   |
				|  	  | Quote: |  	  | In my Main.c program I had in the past needed to place a function
 prototype such as void menu_1100(); and place #include "menu1100.c"
 Based on your explanation, I assume you're doing it as shown in the
 code below.  I don't know why you would have to put the function
 prototype below the #include line.   When the compiler loads the
 include file, it's going to see the function definition.   I can't see why
 you would need the prototype.
 Question:  What previous version of the compiler were you using ?
  	  | Quote: |  	  | #include "Temp.c"  // This file has the menu_1100() function in it
 void menu_1100();   // This line should not be needed
 menu_1100();
		| Jim C Ashby
				|  Posted: Wed Nov 09, 2005 2:56 pm |   |
				| I updated my maintanence contract about a month or so ago, and when I received the CDROM 3.235.23.16 it did not give me an error, only when I updated to the 3.237.7.16 version did I start getting this error.
 I have resolved the problem and I do appreciate the automatic nature of the #include statement I just hope that others are aware of this issue if they have created code a long time ago and find that it no longer compiles witout errors any longer.
