optimization
vin
optimization
PostPosted: Thu Nov 03, 2005 2:33 am     Reply with quote
Dear Sir,
anyone can a brief description about optimisation techniques in CCS C. during programming i encountered with a peculier problem. when my total rom used reaches 75% compiler shows the message "OUT OF ROM". but when i include functions used in submodules in main file(file which contains main declaration) this eoor message is not shown. any one can help me?.
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Thu Nov 03, 2005 3:00 am     Reply with quote
use the #seperate pre-processor directive
there is information about it on this forum
also see:
http://www.pic-c.com/forum/old/messages/1777.html
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Thu Nov 03, 2005 7:43 am     Reply with quote
Though it's not always a cure-all to your out-of-rom problems, it does help to break up long functions into smaller ones. And also to use the #separate directive in front of each function, as was mentioned in the first reply. I use #separate the following way:
#separate
void my_fxn(void); // function prototype
#separate
void my_fxn2(void); // function prototype
void my_fxn(void)
#separate
void my_fxn2(void)
Furthermore, are you using a 16F series PIC? That architecture seems to be notorious for those out-of-rom problems as your code grows. I never have that problem with PIC18F series chips. You might want to consider using an equivalent 18F chip. In fact, with an 18F, i never found the need to use #separate.
Foppie
PostPosted: Thu Nov 03, 2005 8:03 am     Reply with quote
Is this not just because the 18F has more ROM???
MikeValencia
PostPosted: Thu Nov 03, 2005 8:25 am     Reply with quote
I've always been told that the 18F is geared more towards C programming than the 16F. I don't think it's a ROM issue. You say you have only 75% of ROM filled up. It's just that the 16F isn't so tolerant of having long functions that cross "page" boundaries. I haven't written in assembly nor read the datasheets for several years now, so i can't give a concise description.
asmallri
PostPosted: Thu Nov 03, 2005 8:35 am     Reply with quote
The 16F family has a brain dead memory architecture (RAM and Program Memory) that should never have been brought to market - but that's the world we live in :-)
Regards, Andrew
dyeatman
PostPosted: Thu Nov 03, 2005 9:41 am     Reply with quote
FWIW, CCS has a document on CCS optimization vs assembly code on the Overview web page:
http://www.ccsinfo.com/overview.shtml
vin
PostPosted: Thu Nov 03, 2005 11:29 pm     Reply with quote
dear Sir,
Thank all for the valuble information. I am just going to experiment with code. ok we will see again.
