arunb
| What is the meaning of development board ?? |
Posted: Tue Nov 01, 2005 9:05 am |
What is the meaning of development board. Is it possible to program the PIC directly from the PC or does the PIC have to be removed and put in a seperate programmer ??
thanks
arunb |
Posted: Tue Nov 01, 2005 9:18 am |
Many of the "development boards" have the in-circuit serial programming (ICSP) connector on the board and you can program the PIC right on the board. A few even have the entire programmer circuit on the development board.
With the ICSP connector you still have to have an external programmer/interface between the PC and the board like the ICD2 or the ICDU-40 or ICS-40. If you want to buld your own ICSP interface there are a number of them out there to choose from.
treitmey
Posted: Tue Nov 01, 2005 9:20 am |
I think most people on this forum use a programmer or a boot loader.
So
PC connects to a programmer. ((programmer is ICD2 or CCS_ICD-U40))
programmer connects to target board through the ICD port.
Or
You can re-program a board directly from a PC IF [[IF]] that board has allready been programmed with a boot loader.
To get the ' ' ' FIRST' ' ' boot loader on the PICyou still need a programmer. |
MikeValencia
Posted: Tue Nov 01, 2005 9:47 am |
I figured a "development board" is synonymous with a "demo board". They have enough sample circuits on there to fulfill a "proof of concept".
Before the days of ICSP in PICs, your development/demo board obviously didn't have rj11 jacks to program the chip in-circuit. But it was still a development board. |
kender
Posted: Tue Nov 01, 2005 1:06 pm |
| The meaning of a developemnt board is to charge you a few hundred bucks. |
arunb
| RE: |
Posted: Thu Nov 03, 2005 1:37 am |
Is it OK to have a development board and not have ICD or ICSP ,and no on board programming ???
thanks
arunb |
kender
| Re: RE: |
Posted: Thu Nov 03, 2005 1:42 am |
| arunb wrote: | | Is it OK to have a development board and not have ICD or ICSP ,and no on board programming ??? |
No! I haven't seen a PIC development board, which wouldn't require some kind of programmer. |
SherpaDoug
Posted: Thu Nov 03, 2005 7:39 am |
Before flash chips and ICSP it was common for development boards to just have the uC in a socket so you could pop it out to erase and program elsewhere. _________________ The search for better is endless. Instead simply find very good and get the job done. |
asmallri
Joined: 12 Aug 2004 Posts: 1660 Location: Perth, Australia
| Re: RE: |
Posted: Thu Nov 03, 2005 8:33 am |
| kender wrote: | | arunb wrote: | | Is it OK to have a development board and not have ICD or ICSP ,and no on board programming ??? |
Actually there are several develoment boards that have embedded bootloaders and do not reuire ICD or ICSP
http://www.ez-devices.com/asp/listing.asp?cat=1
http://www.picaxe.com _________________ Regards, Andrew
MikeValencia
Posted: Thu Nov 03, 2005 10:17 am |
| Back in the pre-ICSP days of OTP and UV erasable PICs (e.g. PIC16C72), they also sold boards to develop code on. What were those boards called? |
