Harry Mueller
Getting odd values in Interrupt service routine |
Posted: Wed Oct 26, 2005 10:31 am |
This is the program that I'm trying to write for a 6 legged walker. The code has just one servo right now that I'm trying to rotate through a walking cycle within an Interrupt service routine. To try to figure out whats going on, I've printed out values from the ISR to an LCD. They are all off the wall. This is what pops up on the LCD.
flag=20
kount=20
tilt_servo_delay=61312
"flag" shouldn't go over 4, "kount" shouldn't go over 50 and "tilt_servo_delay" shouldn't go over 750.
I've checked out all my books and resources but am totally stumped.
Thanks for any help....Harry
Code: | #include <16F628.h>
#include <LCD_4LINE.c> // this file set up to use port B for LCD
#define TILT_SERVO PIN_A0
#define GP2D02_VIN PIN_B3
#define GP2D02_VOUT PIN_A2
long tilt_servo_delay;
int flag = 0;
int kount = 0;
int reading=0;
//Long_delay_us function==================================
void long_delay_us(long count)
char i;
i = (char)(count >> 8);
while(i >= 1)
i--;
delay_us(253);
restart_wdt();
delay_us((char)count);
//Interrupt Service Routine (ISR)=========================
#int_TIMER0
servo_isr()
int no_of_interrupts;
kount++;
set_timer0 (100); //Preloader to achieve 20 ms period
//Set "walking" servo positions in the ISR===================
switch (flag) // Select case based on value of "flag"========
case '0': no_of_interrupts= 50 ; tilt_servo_delay= 500 ; break;
case '1': no_of_interrupts= 50 ; tilt_servo_delay= 250 ; break;
case '2': no_of_interrupts= 15 ; tilt_servo_delay= 500 ; break;
case '3': no_of_interrupts= 50 ; tilt_servo_delay= 750 ; break;
default : flag = 0; kount = 0; // If "flag" > 3 then start over
// Create desired servo pulse based on case info=============
output_high(TILT_SERVO);
delay_ms(1);
long_delay_us(tilt_servo_delay);
output_low(TILT_SERVO);
if (kount==no_of_interrupts) flag++; // increment "flag" when
} // kount is equal to
// no_of_interrupts
//Collect the IR reading==================================
Collect_IR_Reading()
int counter=9;
output_low(GP2D02_VIN); // start cycle with Vin low
delay_ms(1); // give the sensor a little time before we bug it
while (!input(GP2D02_VOUT)); //wait for Vout to go high
do {
disable_interrupts(GLOBAL);
delay_cycles(4); // minimum wait is 2us, max is 170us, 4 worked
output_low(GP2D02_VIN); // tell the sensor that we want a bit
delay_cycles(2); // might be as low as 1 (maybe), 2 worked
reading=reading<<1; // left shift the reading value
reading=reading|(input(GP2D02_VOUT)); // put the newest reading into the
// LSB of reading
output_high(GP2D02_VIN); // we read bit, and get ready for the next one
counter--;
} while (counter>0);
//LCD print statements====================================
LCD_Print_Routine()
lcd_gotoxy(1,1);
printf(lcd_putc,"Flag = 2%u", flag);
lcd_gotoxy(1,2);
printf(lcd_putc,"kount = 2%u", kount);
lcd_gotoxy(1,3);
printf(lcd_putc,"Value = %3u", reading);
lcd_gotoxy(1,4);
printf(lcd_putc,"delay=%lu", tilt_servo_delay);
// Main Routine========================================
main()
lcd_init();
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_128);
while(true)
Collect_IR_Reading();
LCD_Print_Routine();
Posted: Wed Oct 26, 2005 10:55 am |
There is a simple error causing this. You are testing for '0', not 0 (and the same for the other cases).
The former is the ASCII character representing 0, and has a value of 0x30.
Harry Mueller
Posted: Wed Oct 26, 2005 11:52 am |
Thanks Ttelmah, that was quite obvious....in hindsight.
It's changed the output but it's still weird.
flag cycles between 20 and 23 (approximately)
kount cycles between 2000 and 2900 (approximately)
servo_delay seems right now.
Thanks....Harry |
cmdrdan
Posted: Wed Oct 26, 2005 12:09 pm |
Harry --
Your format statements seem strange for flag and kount. As I read it, you're putting a '2' in front of the variables when you print them out....
Dan |
Harry Mueller
Posted: Wed Oct 26, 2005 8:50 pm |
cmdrdan wrote: | As I read it, you're putting a '2' in front of the variables when you print them out.... |
You're absolutely right! The servo cycles now, there are just some timing issues to work out.
Thanks for your help.....Harry |
