bsodmike
Console output |
Posted: Fri Oct 06, 2006 4:57 am |
I primarily use Mac, but have a couple XP/Linux boxes for various development (MCU/FPGA/Embedded Linux) projects.
Since I would like to code and compile in OS X, the simplest way (as I see is) to setup an OpenSSHd running in XP via Cygwin, then SSH in and compile code over sftp.
The thing is, everytime I ran the PCM executable in the console it causes a pop-up window and any debug output goes in the .err file. Is there an easier way to force the compiler to dump output info to the console? (some args of some sort?)
Mike |
jma_1
Posted: Fri Oct 06, 2006 6:57 am |
Greetings,
I'm not following your description of the setup running Cygwin (GNU Linux tools for Windows) under Windows XP, but using Linux or OS X? I do not follow.
If you have Linux boxes, buy the Linux version of the compiler and continue to do the developement in Linux. If you have the windows version of the compiler, I would not recommend using an emulator like WINE or anything else. You are asking for problems with this route.
I'm assuming you are using the command line verison of the compiler. One of the options is using the +STDOUT option. I have not used this, but it should allow you to capture and view the errors. On windows a sample command line calling might be
"c:\Program Files\Picc\ccsc.exe" +STDOUT +EA +FH +P3 +DF +Y9 +DC +STDOUT +J -T -Z +LNlst +O8hex Main.c
As an alternative, use your favorite editor/IDE and parse the error file. For examples, you might look at the previous post for seting up the compiler for use with CodeWright (project file -> error file, error parser, etc)
Under Windows, CCS does have some sort of executable which can assist in directing where the output goes. I do not remember the details, but CCS was kind enough to send it to me. I never used the executable and decided to use the Windows version of the compiler instead.
Cheers,
JMA |
bsodmike
Posted: Fri Oct 06, 2006 12:39 pm |
jma,
thanks for the tip(s)! Yea, I'm not too hot on using WINE/VPC etc. Getting the linux version is an alternative too, but as I already have the PCM version, Cygwin allows you to install a sort of emulated *nix on windows and setting up a sshd isn't too much trouble. At least that'll save me $125 and work almost as well as the native linux version, besides my programmer is windows dependent.
+STDOUT, thanks that's exactly what I'm after  |
bsodmike
Posted: Sat Oct 07, 2006 4:51 am |
Nope, the +stdout option does not send the err output to the console. Any ideas?
The easiest would be to put the compile string and,
cat main.err
into a bash script. This will work thanks to cygwin  |
bsodmike
Posted: Sat Oct 07, 2006 2:09 pm |
\o/
Code: | [01:33:30] core2duo:~/Desktop/test Administrator$ mcuPCM
CCS PCM C Compiler, Version 3.249 Sun Oct 8 01:33:31 IST 2006
Memory usage: ROM=79% RAM=35% - 74%
0 Errors, 0 Warnings.
I've got it with -EW for the moment. Looking into a way of reading a few lines of the .lst file, might get a c program to do it and output the info just above the memory usage from the err file.
For anyone else that *might* be interested, here's the bash script chmodded to 777,
Code: | #!/bin/bash
echo " "
echo -n "CCS PCM C Compiler, Version 3.249 "
date
echo " "
#-EW to remove warnings!
"/cygdrive/c/Program Files/CCS/Ccsc.exe" +FM +DF +DC +LNlst +T +A +M -Z +J +Y\
9 +EA -EW main.c
cat main.err
echo " "
I've got it in my ~ and that's in my PATH so I can call it from anywhere (and appeares under tab-completion). I also tend to keep my main file as 'main.c' and any other files are included via it.
bsodmike
Posted: Sat Oct 07, 2006 8:02 pm |
Slight improvement,
Code: | // reading a text file
#include <iostream>
#include <fstream>
#include <string>
using namespace std;
int main ()
string line;
int i;
ifstream myfile ("main.lst");
if (myfile.is_open())
for (i=0;i<10;i++)
if (! myfile.eof() )
getline (myfile,line);
cout << line << endl;
myfile.close();
else cout << endl << "Unable to open file main.lst" << endl << endl;
return 0;
And now running the modified script,
Code: | #!/bin/bash
echo " "
"/cygdrive/c/Program Files/CCS/Ccsc.exe" +FM +DF +DC +LNlst +T +A +M -Z +J +Y9 +EA -EW main.c
main
cat main.err
echo " " |
results in,
Code: | $ mcuPCM
CCS PCM C Compiler, Version 3.249, 34595 08-Oct-06 07:28
Filename: main.lst
ROM used: 1439 words (35%)
Largest free fragment is 2048
RAM used: 41 (23%) at main() level
71 (41%) worst case
Stack: 7 worst case (4 in main + 3 for interrupts)
Memory usage: ROM=35% RAM=23% - 41%
I compiled the c program with the output binary as 'main' located in ~/readTXT, which has also been added to my path. |
