morebudwiser
| question about lcdkb |
Posted: Tue Feb 28, 2006 10:14 am |
hi could some explain why when i run the lcdkb example when i press a key the number is displayed on the lcd for only a few seconds before disappearing. i though that each key press should be displayed on the next postion of the lcd and the previous keypress should still be displayed until the * key is pressed to clear the lcd.
many thanks for any help given |
Posted: Tue Feb 28, 2006 12:54 pm |
It sounds like a power supply problem. Possibly. Check the +5v on
your LCD and make sure it stays at +5v, and doesn't drop down to
a lower voltage. |
Posted: Tue Feb 28, 2006 2:34 pm |
hi i am using the 5v from my debugger to power the circuit do you think i need to use an external 5v. and is it ok to connect an external 5v when you have the debugger connected
many thanks for any help |
Posted: Tue Feb 28, 2006 3:28 pm |
| Quote: |
you have the debugger connected |
You first have to configure MPLAB for that mode. I know how to do it
for MPLAB and ICD2. If you have CCS ICD, then I can't help.
1. In MPLAB 7.20, go to the Debugger/Settings menu.
2. In that dialog, select the 'Power' tab.
3. Then un-check the box for " Power target circuit from MPLAB ICD2 (5v Vdd)" and click Apply. |
Posted: Wed Mar 01, 2006 5:02 am |
hi i am using the ccs debugger so i downloaded the hex to the chip and run the target board from a bench psu and measured 5.05v on the lcd supply rail and get the same result the lcd will display ready... and when the key is pressed the value is displayed but for only a few seconds. dont think its a voltage problem as the whole lcd does not blank its only the second line were the keypress is being displayed. the only thing is i have modified the kb driver from 3x4 to 4x4 and have it connected to port c
morebudwiser
Posted: Wed Mar 01, 2006 5:18 am |
| hi got it sorted the problem was that the watchdog was enable in the headerfile so the watchdog time out and reset the pic thus clearing the lcd many thanks to pcm programmer for your help |
