Atma
| LED flashing problem |
Posted: Wed Oct 19, 2005 6:27 am |
Hi there
I am new to using the CCS compiler. I was trying to flash an LED just as a test program but the LED doesnt flash. My code is as below:
#include "C:\Documents and Settings\Atmadarshini dd\My Documents\trial.h"
#include <stdio.h>
#include <stddef.h>
#include <stdlib.h>
#include <string.h>
#int_RDA
#define MCLR PIN_B1
#define DATA_OUT PIN_B2
#define DATA_IN PIN_B4
#define CLOCK PIN_B5
RDA_isr() {
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_RDA);
enable_interrupts(global);
for(;;)
output_low(CLOCK);
delay_ms(200);
output_high(CLOCK);
delay_ms(200);
could someone tell me what i am doing wrong asap.
Thanks |
| Re: LED flashing problem |
Posted: Wed Oct 19, 2005 7:44 am |
| Atma wrote: | #include "C:\Documents and Settings\Atmadarshini dd\My Documents\trial.h"
#include <stdio.h>
#include <stddef.h>
#include <stdlib.h>
#include <string.h>
#int_RDA
#define MCLR PIN_B1
// I'm going to comment this out, as you should
//RDA_isr() { // NEVER leave an empty interrupt handler!!!!
setup_spi(FALSE);
// since you're not using the RDA interrupt, DON'T enable it unless you
// have a proper handler for it!!!
//enable_interrupts(INT_RDA);
//enable_interrupts(global);
//for(;;) I'm going to replace this for loop with something more "standard"
while (TRUE)
output_low(CLOCK);
delay_ms(200);
output_high(CLOCK);
delay_ms(200);
[/code]
Try it with the changes above. |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Wed Oct 19, 2005 7:56 am |
You forgot to add | Code: | | #use delay(clock=....) |
_________________ Regards, Andrew
Humberto
Posted: Wed Oct 19, 2005 8:14 am |
#include <16F877.h> // Change according with your uC
#use delay(clock = 4000000) // change according with the Xtal you are using
output_toggle(PIN_B5);
delay_ms(200);
Humberto
Atma
Posted: Wed Oct 19, 2005 8:17 am |
| newguy wrote: | | Atma wrote: | #include "C:\Documents and Settings\Atmadarshini dd\My Documents\trial.h"
#include <stdio.h>
#include <stddef.h>
#include <stdlib.h>
#include <string.h>
#int_RDA
#define MCLR PIN_B1
Hi i tried it...It didnt work
I have a 1K resistor that is connected to pin RB5 and the resistor goes to LED and the LED is connected to 5V(the postive side of the LED).
The same circuit works when use the cc5x compiler.
setup_spi(FALSE);
while (TRUE)
output_low(CLOCK);
delay_ms(200);
output_high(CLOCK);
delay_ms(200);
[/code]
Atma
Posted: Wed Oct 19, 2005 8:19 am |
| asmallri wrote: | You forgot to add | Code: | | #use delay(clock=....) |
hi this is added in the .h file. so i presume that it gets added to the project. |
Atma
Posted: Wed Oct 19, 2005 8:22 am |
| Humberto wrote: | | Code: |
Humberto |
hi
it says undefined output_toggle when i se your code above |
Humberto
Posted: Wed Oct 19, 2005 8:37 am |
| Quote: |
Output_toggle can be replaced by:
output_high(CLOCK);
delay_ms(200);
output_low(CLOCK);
delay_ms(200);
You would know that in your inquire you must include:
1) Compiler version. (3.xxx format)
2) Full header.
3) Short and concise hardware description.
Keep well,
Humberto |
