I want to send some data(hex file produced by buld from an application) to the bootloader and see it is programming the program memory and running the application (the hex file).
I have opened the hex file , and the data looks different from the actual data read from the program memory.
Why is that?
If I program the memory with the data copied from this hex file, will it work? _________________ Alex
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Wed Oct 19, 2005 4:52 am
How about posting an extract from both _________________ Regards, Andrew
