mke Guest
PIC 16F877A + 3 state encoder (MC145026) |
Posted: Thu Oct 13, 2005 2:01 pm |
I'm working on a circuit for controlling a home garage using PIC 16F877A, a 3 state encoder (Motorola MC145026) and a RF transmitter. The objective is, instead of using DIP switches, to use the PIC to generate the 3-state logic output "1", "0" and "Z" (High, Low and Open/High impedance respectively. This corresponds to +5V, 0V and something between 1.5-2.5V).
The code has 8 different bits and I need another one as TE, so I'm using nine different pins of the PIC connected to nine different input pins of the encoder. I'm using PORT A (RAO-RA5) and PORT E (RE0-RE2) (I canīt not use PORT B and PORT D for some reasons).
For generating "1" I use output_high(), for "0" output_low() and for "Z" output_float(). I have a pullup resistor of 2K to +Vcc in PIN A4 (I know this pin is open drain).
I use PCW Compiler Version 3.227.
The problem is that I only get 0V (0.7V actually) as output voltage in PIC pins when I use output_float().
At the beginning, I managed to get 2V as output voltage in 7 of the 8 pins I was using for output_float() (except in PIN A4. For this pin I only got +5V or +0V). But now, and without any change in the code, I always get 0V for all the pins when using output_float() . At any case, I need 2V for all the pins included, PIN A4 when usin output_float().
Maybe someone can give me any ideas. I post the interesting part of the whole code here. Thank you for your help.
For clarifying the program, input_code corresponds to the code required to open the door encoded in the following way:
"1" => 11
"0" => 00
"Z" => 01
Example: 10ZZ1110 => input_code= 50684 <=>(1100010111111100)
Main.h
#include <16F877A.h>
#device *=16
Main.c
void send_code(WORD16 input_code)
/* For generating outputs voltage levels for input encoder Motorola MC145026*/
/* PIC15F877A */
/* Bit0 => A0
Bit1 => A1
Bit2 => A2
Bit3 => A3
Bit4 => A4
Bit5 => A5
Bit6 => E0
Bit7 => E1
TE => E2
byte8 ax,ax1; /* loop variables */
//BIT0
ax=(input_code>>(15-0))&1;
ax1=(input_code>>(15-1))&1;
if ((ax==1) && (ax1==1))
output_HIGH(PIN_A0);
else if ((ax!=1) && (ax1!=1))
output_LOW(PIN_A0);
output_FLOAT(PIN_A0);
//BIT1
ax=(input_code>>(15-2))&1;
ax1=(input_code>>(15-3))&1;
output_HIGH(PIN_A1);
output_LOW(PIN_A1);
output_FLOAT(PIN_A1);
//BIT2
ax=(input_code>>(15-4))&1;
ax1=(input_code>>(15-5))&1;
output_HIGH(PIN_A2);
output_LOW(PIN_A2);
output_FLOAT(PIN_A2);
//BIT3
ax=(input_code>>(15-6))&1;
ax1=(input_code>>(15-7))&1;
output_HIGH(PIN_A3);
output_LOW(PIN_A3);
output_FLOAT(PIN_A3);
//BIT4
ax=(input_code>>(15-8))&1;
ax1=(input_code>>(15-9))&1;
output_HIGH(PIN_A4);
output_LOW(PIN_A4);
output_FLOAT(PIN_A4);
//BIT5
ax=(input_code>>(15-10))&1;
ax1=(input_code>>(15-11))&1;
output_HIGH(PIN_A5);
output_LOW(PIN_A5);
output_FLOAT(PIN_A5);
//BIT6
ax=(input_code>>(15-12))&1;
ax1=(input_code>>(15-13))&1;
output_HIGH(PIN_E0);
output_LOW(PIN_E0);
output_FLOAT(PIN_E0);
//BIT7
ax=(input_code>>(15-14))&1;
ax1=(input_code>>(15-15))&1;
output_HIGH(PIN_E1);
output_LOW(PIN_E1);
output_FLOAT(PIN_E1);
delay_ms(2000);
output_LOW(PIN_E2); //TE to low state in order to start transmission
WORD16 input_code;
set_tris_a(0x00);
set_tris_e(0x00);
input_code=0b1100010101110011; //10ZZZ101
for(;;)
output_HIGH(PIN_E2); TE = 1 => No transmission
delay_ms(2000);
send_code(input_code);
delay_ms(30000);
Posted: Thu Oct 13, 2005 3:27 pm |
First comment. You cannot use A4.
The voltage you get when a pin is 'floated', is dependant on what circuitry is applied externally. The pull up resistor will ensure this 'floats' to a logic high, and the 'float' state will not be detected properly.
You will not detect the 'float' voltage in normal use. The way that the chip works, is that it tries to pull the floated line high with current source, and sees if it goes high, then tries to pull it low, and sees if it goes low. If the line stay high in both cases it is assumed to be signalling a 'high', if the line goes low, it is assumed to be signalling a 'low', and if the line happily moves to both levels, it is assumed to be 'floated'. The driver always ends by trying to force the pin low, so the floating pins should normally be seen as 0v, with only a tiny pulse of 5v on them.
mke Guest
Posted: Thu Oct 13, 2005 3:59 pm |
So you mean that I can not get a "float" output (something between 1.5-2.5V) using the PIC in any case? Neither for A4 nor for the other pins (A0, A1,E0, E1,... or even using PORT C, B or D? So, I can not emulate a 3-state DIP switch via software? There should be anyway to get it, shouldn't it?
If it's only for A4 maybe I will be able to solve it, but if not...
Anyway, thank you for your collaboration. |
Posted: Fri Oct 14, 2005 2:08 am |
For the other pins, yes of course you can. The point is though, that you _won't_ 'see' 1.5 to 2.5v on the floated pins. The voltage on a floated pin is dependant on what is being done with it, and the detector in the chip you are using does not try to pull the pin to a midway voltage, but tries to pull it frst one way then the other. The floated pins will be left at 0v, slowly drifting to some arbitrary voltage depedant on the leakages round the circuit, and will not sit a the intermediate voltage you expect. The other pins will work fine, but not A4.
