TIMT
Joined: 02 Sep 2005 Posts: 49 Location: Nottingham, UK
| Out of rom error on 16f877a |
Posted: Thu Oct 13, 2005 3:07 am |
Any suggestions? I'm using 88% of rom on my 16f877a project. If I add just one more call to a function i get an "out of rom error" I've seen this mentioned before on the forum. I added #seperate before the function and its prototype as was suggested but now get an error message "invalid pre-processor directive memcpy" I'm moving up to a 18f452 with more memory, hopefully this will cure the problem but it may not... Anyone know a quick fix? I have a lot of fairly large functions and the main is fairly big. Most of my functions are called only once at the moment, so are probably inline, if I start calling them more than once and are placed seperate could this cause further stack/memory problems?
main
Seg 01000-017FF, 0406 left, need 072F
0000
Seg 01800-01FFF, 0800 left, need 0889
0000
Seg 00000-00003, 0000 left, need 0889
0000
Seg 00004-007FF, 000A left, need 0889
0000
Seg 00800-00FFF, 0036 left, need 0889
0000
Seg 01000-017FF, 0406 left, need 0889
0000
*** Error 71 "C:\Program Files\PICC\TIM1.c" Line 1333(0,1): Out of ROM, A segment or the program is too large delay_ms
Halting build on first failure as requested.
BUILD FAILED: Thu Oct 13 09:42:59 2005
_________________ Tim |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
TIMT
| out of rom error |
Posted: Thu Oct 13, 2005 3:35 am |
Thanks for your reply, I am using a lot of short seperate printf("ABC"). I think this may the best place to start economising. After that, I think it's probably best to move up to a 18f452. Do you think using a 18f452 will cure the problem or will I have code which will not fit into one segment?
Thanks again for your help. _________________ Tim |
