18fX52 --> 18FX520, 18FX58 --> 18Fx580
valemike
PostPosted: Sun Oct 09, 2005 8:09 am     Reply with quote
As many are aware, Microchip is recommending the use of the extra "0" suffix part for new designs. However, they do have some subtle erratas.
Does anyone know if the latest versions of PCH/PCWH handle the "workarounds" that are recommended in the errata notes? For example, the newer chips have erratas in ISR handling. At one time, even the legacy 18FX52 chips had erratas where you would need to insert a NOP as the first instruction of an ISR, which CCS promptly handled to avoid user problems.
-Mike
PostPosted: Sun Oct 09, 2005 9:58 am     Reply with quote
Mike,
I played with a 18LF4580 (either that, or it was the regular F part) to get familiar with the CAN bus. I wrote some pretty basic code that used the RTCC (timer 0) interrupt and the CANRX interrupts. No problems at all - it worked just fine.
At the time, I believe that 3.230 was the latest compiler version.
Hope this helps.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Oct 10, 2005 8:53 am     Reply with quote
Okay thanks. It does give me some assurance. Thing is, i'm about to set off a production run, and debating whether to use the more mature 458 than the 4580. After all, it does save money since i can utilize the internal oscillator on the 4580; thus a savings of a crystal, 2 18pF caps, and the $0.75 in savings of not populating them!
treitmey
PostPosted: Mon Oct 10, 2005 9:04 am     Reply with quote
for my 2cents. Prototype that thing with the chip you want to use.
And test the hell out of it.
Don't waist a production run.
PostPosted: Mon Oct 10, 2005 9:44 am     Reply with quote
Ditto what treitmey said. Build one and test. Far less headaches that way.
JimBob
18f452 -> 18f4520
PostPosted: Wed Oct 12, 2005 1:20 pm     Reply with quote
Hi Guys,
Working on a product at the moment. Started developing on 18F452. Having problems when moving to 18F4620. Wandering baud rate on comms. Exactly same settings as for 18F452 project, so my recommendation is as already mentioned here. Test your code on BOTH if you are migrating.
