Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
RHT03 Driver
rikotech8
RHT03 Driver
PostPosted: Sat Mar 15, 2014 8:42 am     Reply with quote
Hello!
In case you have to handle RHT03 (Temperature, Humidity) sensor, here is a driver which is tested. It works! The driver was developed thanks to these topics:
http://www.ccsinfo.com/forum/viewtopic.php?t=51358&highlight=dht22
http://www.ccsinfo.com/forum/viewtopic.php?t=52068
and the members involved in.
This is the code:
#INCLUDE <16F1508.h>
#FUSES INTRC_IO, NOMCLR, WDT_SW, PUT, NOBROWNOUT
#USE delay(internal=16M, restart_wdt)
#USE rs232(BAUD=9600, UART1,ERRORS)
#define RHT_IO Pin_B6
#Define LED PIN_C7
#Include <RHT03.c>
void PrintData(int B1, int B2, int B3, int B4);
void main (void)
int8 i;
int8 ByteIndex[5];
output_high(led);    //Just for debugging WDT reset
output_low(led);
RHT03_Init();
While (True)
   SETUP_WDT(WDT_ON|WDT_32MS);                  //Prevent RHT03 Signal Stuck (will lead an infinite loop)
      restart_wdt();
   RHT_Start();                                 //immediately after this line we must call reading of 40bits data
      for (i=0;i<5;i++)                         //5 bytes being read in this loop
         ByteIndex[i] = RHT_ReadData();
    SETUP_WDT(WDT_OFF);
   if(ByteIndex[0]+ByteIndex[1]+ByteIndex[2]+ByteIndex[3]==ByteIndex[4])
      printf("\r DATA Reception Succesful!");
      printf("\rDATA Garbage!");
   PrintData(ByteIndex[0],ByteIndex[1],ByteIndex[2],ByteIndex[3]);
   delay_ms(2300);                        //The process of data reception must last more than 2secs
int16 humidity;
int16 temperature;
int1 TempSign;                         //the sign of the temperature (either minus or plus)
   TempSign = bit_test(B3,7);          //bit 7 determines if temerature is positive or negative, (=1 negative), (=0 positive)
   humidity = make16(B1,B2);           //assemble entire byte for humidity
   temperature = make16(B3,B4);        //assemble entire byte for temperature
   temperature &= 0b0111111111111111;  //exclude the sign of the temperature so I can convert it to a float value
   if(TempSign)                        //If temperature 15th bit is==1 the temperature value is negative
      printf(" T = -%.1f",(float)temperature/10);   //Note that I manualy put the minus sign
      printf(" T = %.1f",(float)temperature/10);
   printf(" RH = %.1f",(float)humidity/10);
And RHT03.C (driver):
void RHT03_Init(void)
   printf("\fRHT03 Initialization. . .");
   delay_ms(1500);                              //When power is supplied to sensor, don't send any instruction to the sensorwithin one second to pass unstable status
   printf("\fRHT03 Initialization done!");
void RHT_Start()
   output_low(RHT_IO);     // MCU pull low data bus  this process must beyond 1~10ms
   delay_ms(15);           // this process must beyond 1~10ms
   output_float(RHT_IO);   // MCU will pulls up and wait 20-40us for RHT03's response.
   while(input(RHT_IO));   // Wait for RHT03 pulls low the buss for 80uS as response signal
   while(!input(RHT_IO));   // Wait for RHT03 pulls up 80us for preparation to send data
   While(input(RHT_IO));   // RHT03 prepares data for being send (80uS)
int8 RHT_ReadData(void)    //RHT03 is sending data to MCU
int8 iIndex;
int8 iValue=0;
   for(iIndex = 0; iIndex < 8 ; iIndex++) //filling 8bit variable, bit by bit, according to RHT03 input state,
      while(!input(RHT_IO));     // every bit's transmission begin with low-voltage-level that last 50us
      delay_us(35);
      shift_left(&iValue, 1, input(RHT_IO));
   return iValue;
You may change the timings if you consider as right.
Very important thing is not to forget the pull-up resistor 1K on RHT_IO pin!
Enjoy!
A person who never made a mistake never tried anything new.
