Are long and int16 really the same?
SteveW
PostPosted: Tue Sep 27, 2005 3:28 pm     Reply with quote
According to the compiler manual, a long and an int16 are the same. Is this correct? Should long = int32? Typically a long is at least 32 bits.
Regards,
Steve
PostPosted: Tue Sep 27, 2005 3:38 pm     Reply with quote
Yes, in CCS a 'long' and 'int16' are the same.
Note that they are also both unsigned.
SteveW
PostPosted: Tue Sep 27, 2005 4:19 pm     Reply with quote
An int16 is unsigned? Wow, I would have never guessed that! Thanks, you just potentially save me a lot of headaches. So, for an integer of any type to be signed, it must explicitly be declared as signed? I have never seen a C compiler with this "feature". Is there a reason for it?
Regards,
Steve
PostPosted: Tue Sep 27, 2005 4:30 pm     Reply with quote
Somewhere there is a post I think, by Ttelmah, that speculates on
why CCS did it this way, but I can't find it. But I did find
a whole thread of screaming on the topic. LOL.
http://www.ccsinfo.com/forum/viewtopic.php?t=1073&start=0
SteveW
PostPosted: Tue Sep 27, 2005 5:08 pm     Reply with quote
Interesting thread. I am now very happy that I started reading the manual before using the product. I would have never considered that a default int would be unsigned. I can live with this quirk, but how many more are there? Back to my reading.
Thanks again,
Steve
PostPosted: Wed Sep 28, 2005 4:22 am     Reply with quote
It works the other way. I now code in CCS 99% of the time and try and use CCS "C" in the real world as well!
SherpaDoug
PostPosted: Wed Sep 28, 2005 7:25 am     Reply with quote
It is always eye-opening for C++ programmers when I explain that I can't just add another flag to my old 16C54 code because I have already used the extra bits available in the Status register and adding another short would require a whole byte which I just don't have!
treitmey
PostPosted: Wed Sep 28, 2005 8:21 am     Reply with quote
yes, keep hold of all those spare bits. Don't use a byte when a bit will do.
