		| Author | Message |
		| Foppie
				| kbhit problem |
				|  Posted: Fri Sep 23, 2005 4:46 am |   |
				| Hello,
 when I use kbhit() in my code after a printf() statement. I seem always to get TRUE as a result from kbhit(), even when I can't receive anything. Is that true, or is my code bugged? (I wrote it 4 times in different ways, but always get the same results....)
 Can someone help me?
  	  | Code: |  	  | #device PIC16F877A *=16 ADC=10 #include <drivers/16f877.h>
 #FUSES NOWDT       //No Watch Dog Timer
 #FUSES HS       //High speed Osc (> 4mhz)
 #FUSES NOPROTECT    //Code not protected from reading
 #FUSES NOLVP       //Low Voltage Programming on B3
 #FUSES NOCPD       //No EE protection
 #FUSES NOWRT       //Program memory not write protected
 #use rs232(baud=9600, parity=n, bits=8, xmit=PIN_C6, rcv=PIN_C7, errors, stream=UWEAVE)
 short checknetwork(int try)
 // Input  : void
 // Output : short - connected to network(1) or not connected(0)
 // Action : connects to network
 short result, connected;
 int i;
 char data[80];
 i = 0;
 result = FALSE;
 connected = FALSE;
 lcd_gotoxy(1,1);
 printf(lcd_putc, "\fConnecting...");
 lcd_gotoxy(1,2);
 printf(lcd_putc, "try: %u", try);
 puts("ATE?");
 for(i = 0; ((i <= 79) && (!result)); i++)
 while(!kbhit()) delay_us(10);
 data[i]=getc();
 if (i > 1)
 if ((data[i - 1] == 'O') && (data[i] == 'K'))
 result = TRUE;
 connected = TRUE;
 if (i > 4)
 if ((data[i - 4] == 'E') && (data[i - 3] == 'R') && (data[i - 2] == 'R') && (data[i - 1] == 'O') && (data[i] == 'R'))
 result = TRUE;
 lcd_gotoxy(1,1);
 printf(lcd_putc, "\fdata: ", data);
 delay_ms(2000);
 return connected;
 lcd_init();
 //establish connection
 while(!checknetwork(i++));
		| PCM programmer
				|  Posted: Fri Sep 23, 2005 11:42 am |   |
				| My suggestion is, get rid of all the parsing code and write a small test program.  i.e., no more than 6 lines of code inside main().
 If you can demonstrate the error, then post that program and also
 post the version of your compiler.
		| Foppie
				|  Posted: Mon Sep 26, 2005 2:49 am |   |
				| I now have it working using an interrupt.
 Thanks for the advice to make a small test program first. I think I just wanted to much in once...
 | You cannot post new topics in this forum You cannot reply to topics in this forum
