ICD2 problem
luissito
ICD2 problem
PostPosted: Sat Sep 17, 2005 4:45 am     Reply with quote
Hi , well this is my first post so don't be bad Wink . I am running CCS compiler under MPLAB, using the microchip ICD2 debugger , in debug mode it works fine, but if I use the ICD2 in programmer mode my program doesn't run on the PIC although mplab says ....programming succeeded. Any suggestions??
Thank's in advance.
Regards.
PostPosted: Sat Sep 17, 2005 7:58 am     Reply with quote
After programming, did you remove the programming cable? With the cable attached the ICD2 will keep the PIC in reset mode unless you select the 'release from reset' button in MPLAB (the button with the up arrow).
luissito
PostPosted: Sat Sep 17, 2005 2:14 pm     Reply with quote
Yep I remove the programming cable but it still doesn't work, I don't find that button with the up arrow. By the way I am using mplab 6.40 but that shouldn't be a problem.
Regards
PostPosted: Sat Sep 17, 2005 3:44 pm     Reply with quote
What chip are you using?
Are you using an 18F series in 4xPLL mode?
luissito
PostPosted: Sat Sep 17, 2005 4:13 pm     Reply with quote
No, I am using a PIC16F873. It's a strange thing what happens, works perfect in debug mode but in programmer mode it does nothing.
Regards
drolleman
PostPosted: Sat Sep 17, 2005 9:01 pm     Reply with quote
do you have a pull up resistor on mclr?
Mark
PostPosted: Sat Sep 17, 2005 11:34 pm     Reply with quote
The earlier versions allowed you to load the Debugger and the Programmer at the same time. If your version does this, make sure that you have the debugger configuration turned off.
luissito
PostPosted: Sun Sep 18, 2005 1:59 am     Reply with quote
I don't have a pull-up resistor on MCLR and I disable debugger mode before enabling programmer mode.
Mark
PostPosted: Sun Sep 18, 2005 8:28 am     Reply with quote
Well you need one on it. Look up the schematic of a PIC demo board, like a PICDEM 2 PLUS, from Microchip's website. Look at how they connect MCLR.
luissito
PostPosted: Sun Sep 18, 2005 8:40 am     Reply with quote
Thank's everybody, it was that, I have just soldered the pull up resistor and everything goes fine.
Regards.
