rnielsen
| Component suggestions wanted |
Posted: Fri Sep 16, 2005 10:38 am |
Greetings!
I am looking for suggestions on various components that might be good for a project I need to start.
Description:
I have an arm, mounted on a linear bearing, that is being moved up and down with a cylinder. I need to measure the amount of force/impact that the arm is striking a plate. I've thought about a force sensor or some kind of impact sensor. I thought I would sample the amplifier output at a high frequency if I used a force sensor, or something like that. The sensor needs to be smaller than .5" square/diameter and measure a max. of 1500g force.
Any suggestions? I've tried google and looked in various places but wanted to see if I could poll the expertise here and get some good ideas.
Thanks,
Ronald |
