many o pic's o where thou go ?
PostPosted: Thu Sep 08, 2005 6:43 pm     Reply with quote
guess you got to interconnent 17 PIC18F44XX.
One of these, it connectes to RS232,
You need to update all o these over the serial line, tell me about
possible conns, the other 16 are connected to the first PIC.
It's got to work all the time.
Faulty action means -$$$.
Yes, I'll use 17 Pic's in my project.
Ill try hard workin' out the bootloader + encryption (if someone makes things clear how I can Protect my stuff with it).
So, what type of interface, daisy chain,, .. / ??
It's 18 F XXXX
Thanks Martin
asmallri
Re: many o pic's o where thou go ?
PostPosted: Thu Sep 08, 2005 6:59 pm     Reply with quote
I do something very similar with serial, SPI and Ethernet implementations.
For the serial implementation, the primary PIC has a RS232 interface which is used for the bootloader. All other PICs are connected to the primary PIC over a RS485 bus. My application is a distributed data acquisition system with the RS485 bus being used for data and bootloading. The bootloader on the primary PIC has a "transparent mode". When the primary is in bootloader mode, I can sent it a bootloader command to go into "transparent mode" in which case it will echo all data transparently between the RS232 and RS485 busses. Each device on the RS485 bus is addressable. I send a command to the specific PIC I want to bootload to cause it to reset (my bootloaders are only active within the first few seconds of reset). Once the target PIC is reset I "capture" it with the bootloader and then load new code to the target PIC. When I have finished bootloading the slave PIC I "release" the slave and it reboots. When I have finished bootloading the slaves, the master pic is taken out of transparent mode and reset.
I have used similar mechanisms for bootloading over SPI and Ethernet. In one case I used RS232 to the Primary PIC, RS485 to the first tier of multiple slave PICs and SPI between the slave PICs and MAXIM 1463 MPU based A/D subsystem.
Regards, Andrew
PostPosted: Thu Sep 08, 2005 7:22 pm     Reply with quote
Please, asmallri,
is it a mistery at all,
I do't think so.
Why (how) use encryption ????????????????
Thanks Martin
SherpaDoug
PostPosted: Fri Sep 09, 2005 7:26 am     Reply with quote
How far are the slave PICs from the master? If it is less than a couple of meters I would use SPI to connect the PICs together. If data errors would be catastrophic add checksums to the data messages.
Do you really need a bootloader? Security is simpler without one.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Fri Sep 09, 2005 4:42 pm     Reply with quote
To interconnect all those PICs together, wouldn't CAN be one of the top candidates?
