Rocket Guest
| Help on BIT definition please |
Posted: Fri Aug 26, 2005 2:20 am |
Hi all. I need to make a driver, that works for the 16 and 18 parts.
And the input signal can be on CCP1 in or CCP2 in, so this is where I fall off the bus. My code looks like this..
#if defined(__PCH__)
#if defined use_CCP2
#byte CCP_CON = 0xFBA // CCP2CON Reg
#bit CCP_Flag = 0xFA1,0 // CCP2IF FLAG
#else
#byte CCP_CON = 0xFBD // CCP1CON Reg
#bit CCP_Flag = 0xF9E,2 // CCP1IF FLAG
#byte PIR1 = 0xF9E // PIR1 Reg
#else
#byte CCP_CON = 0x1D // CCP2CON Reg
#bit CCP_Flag = 0x0D,0 // CCP2IF FLAG
#else
#byte CCP_CON = 0x17 // CCP1CON Reg
#bit CCP_Flag = 0x0C,2 // CCP1IF FLAG
#byte PIR1 = 0x0C // PIR1 Reg
the "#bit" does not work, and i need to test for the relevant CCP interupt flag in my program..
Thanx.. |
Posted: Fri Aug 26, 2005 2:46 am |
The 'bit' seperator, is a '.' not a ','...
#bit CCP_Flag = 0xFA1.0 // CCP2IF FLAG
