"GOTO <Label>" functionality broken in PCM 3
Paul Klissner
PostPosted: Mon Nov 19, 2001 2:52 am     Reply with quote
Example of code that demonstrates broken 'goto' functionality:
int i,j;
for (i=0;i<255;i++)
for (j=0;j<255;j++)
if (i=100 && j=100)
goto loopexit;
loopexit:
Doesn't work. The following compile-time message is generated:
Error[88] xxx.c 101 : Undefined label that was used in a GOTO loopexit
This is an important feature, otherwise C-code gets ugly
breaking nested switch(),for() and while() statements, where
code has to check extra flags. Hardcore computer science
clearly states this is *the* legitimate and preferred use
of goto, and is the superior choice when breaking nests.
Original Post ID: 1223
dan
Re: "GOTO <Label>" functionality broken in P
PostPosted: Mon Nov 19, 2001 9:03 pm     Reply with quote
I sent the problem to CCS, they added a goto_address cmd. in ver 3.059 and broke the regular goto. They should have it fixed in a day or so.
I had a little luck getting it to work by adding the cmd. x= address_(label) or what ever it was, but had to back up to ver 3.043 to get through the week-end and my current project.
Like an idiot, I didn't keep the latest working copy, before I upgraded.
Those commands are in the read me, but I'd have to reload the buggy ver to read them.
Your right, sometimes the old basic goto is the best way out of a nest!
Dan
:=Example of code that demonstrates broken 'goto' functionality:
:= int i,j;
:= for (i=0;i<255;i++)
:= for (j=0;j<255;j++)
:= if (i=100 && j=100)
:= goto loopexit;
:=loopexit:
:=Doesn't work. The following compile-time message is generated:
:=Error[88] xxx.c 101 : Undefined label that was used in a GOTO loopexit
:=This is an important feature, otherwise C-code gets ugly
:=breaking nested switch(),for() and while() statements, where
:=code has to check extra flags. Hardcore computer science
:=clearly states this is *the* legitimate and preferred use
:=of goto, and is the superior choice when breaking nests.
Original Post ID: 1243
Curt
PostPosted: Fri Nov 23, 2001 3:58 pm     Reply with quote
Important feature? Yes I'll grant its sometimes needed to optimize code to reduce opcode count, but thats about it.
your assertions about "hardcore computer science" interest me.
I am curious to see a piece of code that is necessarily "ugly" without goto.
-Curt
:= int i,j;
:= goto loopexit;
:=loopexit:
Original Post ID: 1309
Dave Y.
PostPosted: Sun Nov 25, 2001 11:18 am     Reply with quote
I had the same problem, however, simply adding a dummy statement line after the label works.
here is your example with the fix
:=:= int i,j;
:=:= for (i=0;i<255;i++)
:=:= for (j=0;j<255;j++)
:=:= if (i=100 && j=100)
:=:= goto loopexit;
:=:=loopexit:
:=:= i=1; <== dummy == this makes it work for me....
:=I sent the problem to CCS, they added a goto_address cmd. in ver 3.059 and broke the regular goto. They should have it fixed in a day or so.
:= I had a little luck getting it to work by adding the cmd. x= address_(label) or what ever it was, but had to back up to ver 3.043 to get through the week-end and my current project.
:= Like an idiot, I didn't keep the latest working copy, before I upgraded.
:=Those commands are in the read me, but I'd have to reload the buggy ver to read them.
:=Your right, sometimes the old basic goto is the best way out of a nest!
:=Dan
:=:=Example of code that demonstrates broken 'goto' functionality:
:=:= int i,j;
:=:= goto loopexit;
:=:=loopexit:
:=:=Doesn't work. The following compile-time message is generated:
:=:=Error[88] xxx.c 101 : Undefined label that was used in a GOTO loopexit
:=:=This is an important feature, otherwise C-code gets ugly
:=:=breaking nested switch(),for() and while() statements, where
:=:=code has to check extra flags. Hardcore computer science
:=:=clearly states this is *the* legitimate and preferred use
:=:=of goto, and is the superior choice when breaking nests.
Original Post ID: 1314
Karel Hladky
PostPosted: Fri Nov 30, 2001 3:49 am     Reply with quote
:=I had the same problem, however, simply adding a dummy statement line after the label works.
Even simpler, just stick a semicolon after your label :
loopexit:;
Karel
Original Post ID: 1394
