		| Author | Message |
		| candyman561
				| PIC thermometer not display neg. temp. |
				|  Posted: Sat Mar 22, 2008 2:59 pm |   |
				| HI.....I am new in the CCS C community and I need help!!!! I am using a PIC 16f628 for a clock/thermometer with DS1307 and DS18S20....it works OK BUT...the thermometer does not display negative temp. How can I change the codes to display negative temp ?  The project was compiled with CCS V 3.222    I do have the name of the site where you can see this program:
  	  | Code: |  	  | // DIGITAL thermometer project
 // Compiler : CCS V 3.222
 #include <16F628.h>
 #fuses NOWDT,XT, NOPUT, PROTECT,NOLVP,NOMCLR,NOLVP  // for 628
 //#fuses NOWDT,XT, NOPUT, PROTECT    // for 84a
 #include <ds1820.c>
 #define DS1307_SDA  PIN_A2
 #define DS1307_SCL  PIN_A3
 #use i2c(master, sda=DS1307_SDA, scl=DS1307_SCL)
 byte CONST MAP1[10]={0xFA,0x30,0xD9,0x79,0X33,0x6B,0xEB,0x38,0xFB,0x7B};
 byte CONST MAP2[10]={0xDE,0x18,0xCD,0x5D,0X1B,0x57,0xD7,0x1c,0xDF,0x5F};
 byte sec,min,hour;
 byte fs_flag;
 #define EXP_OUT_LATCH   PIN_B7
 #define EXP_OUT_CLOCK   PIN_B3
 #define EXP_OUT_DO      PIN_B5
 #define EXP_OUT_CLEAR   PIN_B6
 #define colon           PIN_B4
 #define DEC             PIN_B1
 #define INC             PIN_B2
 BYTE buff[9], sensor, n,temp,temp_dec,RES;
 BYTE D_SHIFT;
 // initial DS1307
 void init_DS1307()
 output_float(DS1307_SCL);
 output_float(DS1307_SDA);
 // write data one byte to
 // DS1307
 void write_DS1307(byte address, BYTE data)
 short int status;
 i2c_start();
 i2c_write(0xd0);
 i2c_write(address);
 i2c_write(data);
 i2c_stop();
 i2c_start();
 status=i2c_write(0xd0);
 while(status==1)
 i2c_start();
 // read data one byte from DS1307
 BYTE read_DS1307(byte address)
 BYTE data;
 i2c_start();
 i2c_write(0xd0);
 i2c_write(address);
 i2c_start();
 i2c_write(0xd1);
 data=i2c_read(0);
 i2c_stop();
 return(data);
 // WRITE DATA TO 6B595
 void write_expanded_outputs(BYTE *D)
 BYTE i;
 for(i=1;i<=8;++i)
 {  // Clock out bits from the eo array
 if ((D & 0x80)==0)
 output_low(EXP_OUT_DO);
 output_high(EXP_OUT_DO);
 D=D<<1;
 output_high(EXP_OUT_CLOCK);
 output_low(EXP_OUT_CLOCK);
 // show temperature
 void show_temp()
 int8 count;
 output_high(colon);
 for (count=0;count<8;count++)  // blink temperature 8 times
 output_low(EXP_OUT_LATCH);
 sensor=0;   // DS1820 CONNECT TO PIN A0
 init_ds1820(sensor);
 write_ds1820_one_byte(0xcc, sensor);  // skip ROM
 write_ds1820_one_byte(0x44, sensor);  // perform temperature conversion
 while (read_ds1820_one_byte(sensor)==0xff); // wait for conversion complete
 write_ds1820_one_byte(0xbe, sensor);  // read the result
 for (n=0; n<9; n++)     // read 9 bytes but, use only one byte
 buff[n]=read_ds1820_one_byte(sensor);  // read DS1820
 temp=buff[0]>>1;
 if ((buff[0] & 0x1)==1)
 temp_dec=5;
 temp_dec=0;
 D_SHIFT=0x00;
 write_expanded_outputs(D_SHIFT);
 D_SHIFT=0xE1;  // show 'C
 RES=TEMP%10;
 D_SHIFT=MAP1[RES];
 RES=TEMP/10;
 if (RES==0)
 D_SHIFT=0x00;
 D_SHIFT=MAP1[RES];
 output_high(EXP_OUT_LATCH);
 for (n=1;n<=4;n++)
 D_SHIFT=0x00;
 // show time 1
 void show_time1()
 byte m;
 output_low(colon);
 min=read_ds1307(1);
 hour=read_ds1307(2);
 m=min & 0x0F;
 D_SHIFT=MAP2[m];
 swap(min);
 m=min & 0x07;
 D_SHIFT=MAP2[m];
 m=hour & 0x0F;
 D_SHIFT=MAP1[m];
 swap(hour);
 m=hour & 0x03;
 D_SHIFT=MAP1[m];
 swap(min);
 swap(hour);
 // check switch
 void check_sw()
 byte j;
 if (fs_flag!=0)
 if (!input(INC))
 if (fs_flag==1)
 min=read_ds1307(1);
 min++;
 j=min & 0x0F;
 if (j>=0x0A) min=min+0x06;
 if (min>=0x60) min=0;
 write_ds1307(1,min);
 hour++;
 j=hour & 0x0F;
 if (j>=0x0A) hour=hour+0x06;
 if (hour>=0x24) hour=0;
 write_ds1307(2,hour);
 show_time1();
 if (!input(DEC))
 if (fs_flag==1)
 min=read_ds1307(1);
 if (min!=0)
 min--;
 j=min & 0x0F;
 if (j>=0x0A) min=min-0x06;
 else min=0x59;
 if (hour!=0)
 hour--;
 j=hour & 0x0F;
 if (j>=0x0A) hour=hour-0x06;
 else hour=0x23;
 show_time1();
 // show time
 void show_time(byte fs)
 byte m;
 output_low(colon);
 min=read_ds1307(1);
 m=min & 0x0F;
 D_SHIFT=MAP2[m];
 swap(min);
 m=min & 0x07;
 D_SHIFT=MAP2[m];
 m=hour & 0x0F;
 D_SHIFT=MAP1[m];
 swap(hour);
 m=hour & 0x03;
 D_SHIFT=MAP1[m];
 swap(min);
 swap(hour);
 check_sw();
 check_sw();
 check_sw();
 check_sw();
 check_sw();
 //delay_ms(500);
 if (fs==0)
 output_high(colon);
 //delay_ms(500);
 if (fs==1)
 output_high(colon);
 D_SHIFT=0x00;
 D_SHIFT=0x00;
 m=hour & 0x0F;
 D_SHIFT=MAP1[m];
 swap(hour);
 m=hour & 0x03;
 D_SHIFT=MAP1[m];
 //delay_ms(500);
 output_high(colon);
 m=min & 0x0F;
 D_SHIFT=MAP2[m];
 swap(min);
 m=min & 0x07;
 D_SHIFT=MAP2[m];
 D_SHIFT=0x00;
 D_SHIFT=0x00;
 //delay_ms(500);
 check_sw();
 check_sw();
 check_sw();
 check_sw();
 check_sw();
 #int_EXT
 void EXT_isr()
 fs_flag++;
 if (fs_flag>=3) fs_flag=0;
 // main program start here
 byte u;
 delay_ms(5);
 port_b_pullups(true);
 output_low(EXP_OUT_CLEAR);
 delay_us(10);
 output_high(EXP_OUT_CLEAR);
 for(RES=0;RES<80;RES++)
 init_ds1307();
 u=read_ds1307(0);
 sec=u & 0x7F;// enable RTC
 write_ds1307(0,sec);   // set second to 00 and enable clock(bit7=0)
 fs_flag=0;
 ext_int_edge(H_TO_L);      // init interrupt triggering for button press
 enable_interrupts(INT_EXT);
 while(true)
 disable_interrupts(INT_EXT);
 if (fs_flag==0)
 show_temp();
 for (u=0;u<20;u++)
 show_time(fs_flag);
 } //end of main program
		| Guest
				|  Posted: Mon Mar 24, 2008 6:53 pm |   |
				| Hi,
 If you really want to receive some help, you've got to break the problem down into a manageable chunk. The code you posted is far too long for someone to wade through, and most of it is irrelevant to your problem. I suggest that you create a small program that includes only the temp. measurement stuff, and then tell us what IS happening vs. what you expect to happen.
 Cheers,
 George
		| Guest
				|  Posted: Mon Mar 24, 2008 8:43 pm |   |
				| You're reading nine bytes from the 1820, but you're not doing anything with any of them except the first!  In reading through the chip's datasheet, you'll find that the second byte contains the sign information for the temperature; if it isn't zero, then you'll need to perform a two's complement on the first byte to get the magnitude.
 If byte two is non-zero, invert the bits of byte one and add one to the result.  If byte two is zero, then do nothing to byte one.  Remember that bit 0 represents half-degrees, so you'll have to shift byte one to the right one place to read out in full degrees...
 | You cannot post new topics in this forum You cannot reply to topics in this forum
