PN532 RFID / NFC tag reader driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
mohammad3d
PostPosted: Wed Oct 17, 2018 1:56 am     Reply with quote
Hi every one,
I try to convert ARDUNIO PN532 ntag2xx reader example and library to
CCS C version on PIC16f877 device.
You can find original source code by "Adafruit Industries" in following address:
https://github.com/adafruit/Adafruit-PN532
The following is my code and it work like ardunio version on my PIC device.
The program send all data and messages on serial port.
you can monitor program output with a serial monitor software.
This program tested and fully worked...
main.c (main program file):
//main.c File
#include <16F887.h>
#FUSES NOLVP                    //No low voltage programing, B3(PIC16) or B5(PIC18) used for I/O
#FUSES HS
#use delay(crystal=4000000)//Set frequency at 4Mhz
#use rs232( baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8, ERRORS)
//Note:Connect PN532 module to 5v PIC without any Level converter .It'll work fine.
//Note:PN532 work in SPI slave mode(PIC is MASTER)
//PN532 connection PIN
#define _SS PIN_C2//PN532 chip select pin(SS) to PIC pin17
#define _clk PIN_C3//PIC pin17
#define _mosi PIN_C5//PIC pin24
#define _miso PIN_C4//PIC pin23
//PN532 module MOSI pin to PIC16f877 pin 24(RC5/SDO)
//PN532 module MISO pin to PIC16f877 pin 23(RC4/SDI)
//PN532 module SCK  pin to PIC16f877 pin 18(RC3/SCK)
//pre define for compiler compatibility
#define bool int1
#define uint8_t unsigned int8
#define uint16_t unsigned int16
#define uint32_t unsigned int32
#define LOW   0
#define HIGH   1
#define digitalWrite output_bit
#define digitalRead input
#define _BV(bit) (1<<(bit))
#define delay delay_us
#define PN532_PACKBUFFSIZ 64
byte pn532ack[] = {0x00, 0x00, 0xFF, 0x00, 0xFF, 0x00};
byte pn532response_firmwarevers[] = {0x00, 0xFF, 0x06, 0xFA, 0xD5, 0x03};
byte pn532_packetbuffer[PN532_PACKBUFFSIZ];
//#define PN532DEBUG  //uncomment to see debug messages
#include <string.h>
#include <PN532.h>
#include <PN532.c>
void main(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;   // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  uint8_t data[32];
  uint32_t versiondata;
  printf("\n\r Hello\n\r");
  begin();
  versiondata = getFirmwareVersion();
   if (! versiondata) {
    printf("\n\rDidn't find PN53x board\n\r");
    while (true); // halt
  // Got ok data, print it out!
  printf("\n\rFound chip PN5%x\n\r",((versiondata>>24) & 0xFF));
  printf("Firmware ver. %lu.%lu\n\r",((versiondata>>16) & 0xFF),((versiondata>>8) & 0xFF));
  // configure board to read RFID tags
  SAMConfig();
  while(true)
       printf("Waiting for an ISO14443A Card ...\n\r");
      // Wait for an NTAG203 card.  When one is found 'uid' will be populated with
      // the UID, and uidLength will indicate the size of the UUID (normally 7)
      success = readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength,0);
      if (success) {
           // Display some basic information about the card
           printf("Found an ISO14443A card\n\r");
           printf("  UID Length:%u bytes\n\r",uidLength);
           printf("  UID Value: ");
           PrintHex(uid, uidLength);
           printf("\n\r");
           if (uidLength == 7)
                // We probably have an NTAG2xx card (though it could be Ultralight as well)
                printf("Seems to be an NTAG2xx tag (7 byte UID)\n\r");
                printf("\n\r");
                // NTAG2x3 cards have 39*4 bytes of user pages (156 user bytes),
                // starting at page 4 ... larger cards just add pages to the end of
                // this range:
                // See: http://www.nxp.com/documents/short_data_sheet/NTAG203_SDS.pdf
                // TAG Type       PAGES   USER START    USER STOP
                // NTAG 203       42      4             39
                // NTAG 213       45      4             39
                // NTAG 215       135     4             129
                // NTAG 216       231     4             225
                for (uint8_t i = 0; i < 42; i++)
                       success = ntag2xx_ReadPage(i, data);
                       // Display the current page number
                       printf("PAGE ");
                       if (i < 10)   printf("0%u",i);
                          else     printf("%u",i);
                       printf(": ");
                       // Display the results, depending on 'success'
                       // Dump the page data
                       if (success) PrintHexChar(data, 4);
                          else   printf("Unable to read the requested page!\n\r");
                else    printf("This doesn't seem to be an NTAG203 tag (UUID length != 7 bytes)!\n\r");
         // Wait a bit before trying again
         printf("\n\n\rSend a character to scan another tag!\n\r");
         while(!kbhit());
         getch();
PN532.H (PN532 commands file)
//PN532.h
#define PN532_PREAMBLE                      0x00
#define PN532_STARTCODE1                    0x00
#define PN532_STARTCODE2                    0xFF
#define PN532_POSTAMBLE                     0x00
#define PN532_HOSTTOPN532                   0xD4
#define PN532_PN532TOHOST                   0xD5
// PN532 Commands
#define PN532_COMMAND_DIAGNOSE              0x00
#define PN532_COMMAND_GETFIRMWAREVERSION    0x02
#define PN532_COMMAND_GETGENERALSTATUS      0x04
#define PN532_COMMAND_READREGISTER          0x06
#define PN532_COMMAND_WRITEREGISTER         0x08
#define PN532_COMMAND_READGPIO              0x0C
#define PN532_COMMAND_WRITEGPIO             0x0E
#define PN532_COMMAND_SETSERIALBAUDRATE     0x10
#define PN532_COMMAND_SETPARAMETERS         0x12
#define PN532_COMMAND_SAMCONFIGURATION      0x14
#define PN532_COMMAND_POWERDOWN             0x16
#define PN532_COMMAND_RFCONFIGURATION       0x32
#define PN532_COMMAND_RFREGULATIONTEST      0x58
#define PN532_COMMAND_INJUMPFORDEP          0x56
#define PN532_COMMAND_INJUMPFORPSL          0x46
#define PN532_COMMAND_INLISTPASSIVETARGET   0x4A
#define PN532_COMMAND_INATR                 0x50
#define PN532_COMMAND_INPSL                 0x4E
#define PN532_COMMAND_INDATAEXCHANGE        0x40
#define PN532_COMMAND_INCOMMUNICATETHRU     0x42
#define PN532_COMMAND_INDESELECT            0x44
#define PN532_COMMAND_INRELEASE             0x52
#define PN532_COMMAND_INSELECT              0x54
#define PN532_COMMAND_INAUTOPOLL            0x60
#define PN532_COMMAND_TGINITASTARGET        0x8C
#define PN532_COMMAND_TGSETGENERALBYTES     0x92
#define PN532_COMMAND_TGGETDATA             0x86
#define PN532_COMMAND_TGSETDATA             0x8E
#define PN532_COMMAND_TGSETMETADATA         0x94
#define PN532_COMMAND_TGGETINITIATORCOMMAND 0x88
#define PN532_COMMAND_TGRESPONSETOINITIATOR 0x90
#define PN532_COMMAND_TGGETTARGETSTATUS     0x8A
#define PN532_RESPONSE_INDATAEXCHANGE       0x41
#define PN532_RESPONSE_INLISTPASSIVETARGET  0x4B
#define PN532_WAKEUP                        0x55
#define PN532_SPI_STATREAD                  0x02
#define PN532_SPI_DATAWRITE                 0x01
#define PN532_SPI_DATAREAD                  0x03
#define PN532_SPI_READY                     0x01
#define PN532_I2C_ADDRESS                   0x48 >> 1
#define PN532_I2C_READBIT                   0x01
#define PN532_I2C_BUSY                      0x00
#define PN532_I2C_READY                     0x01
#define PN532_I2C_READYTIMEOUT              20
#define PN532_MIFARE_ISO14443A              0x00
// Mifare Commands
#define MIFARE_CMD_AUTH_A                   0x60
#define MIFARE_CMD_AUTH_B                   0x61
#define MIFARE_CMD_READ                     0x30
#define MIFARE_CMD_WRITE                    0xA0
#define MIFARE_CMD_TRANSFER                 0xB0
#define MIFARE_CMD_DECREMENT                0xC0
#define MIFARE_CMD_INCREMENT                0xC1
#define MIFARE_CMD_STORE                    0xC2
#define MIFARE_ULTRALIGHT_CMD_WRITE         0xA2
// Prefixes for NDEF Records (to identify record type)
#define NDEF_URIPREFIX_NONE                 0x00
#define NDEF_URIPREFIX_HTTP_WWWDOT          0x01
#define NDEF_URIPREFIX_HTTPS_WWWDOT         0x02
#define NDEF_URIPREFIX_HTTP                 0x03
#define NDEF_URIPREFIX_HTTPS                0x04
#define NDEF_URIPREFIX_TEL                  0x05
#define NDEF_URIPREFIX_MAILTO               0x06
#define NDEF_URIPREFIX_FTP_ANONAT           0x07
#define NDEF_URIPREFIX_FTP_FTPDOT           0x08
#define NDEF_URIPREFIX_FTPS                 0x09
#define NDEF_URIPREFIX_SFTP                 0x0A
#define NDEF_URIPREFIX_SMB                  0x0B
#define NDEF_URIPREFIX_NFS                  0x0C
#define NDEF_URIPREFIX_FTP                  0x0D
#define NDEF_URIPREFIX_DAV                  0x0E
#define NDEF_URIPREFIX_NEWS                 0x0F
#define NDEF_URIPREFIX_TELNET               0x10
#define NDEF_URIPREFIX_IMAP                 0x11
#define NDEF_URIPREFIX_RTSP                 0x12
#define NDEF_URIPREFIX_URN                  0x13
#define NDEF_URIPREFIX_POP                  0x14
#define NDEF_URIPREFIX_SIP                  0x15
#define NDEF_URIPREFIX_SIPS                 0x16
#define NDEF_URIPREFIX_TFTP                 0x17
#define NDEF_URIPREFIX_BTSPP                0x18
#define NDEF_URIPREFIX_BTL2CAP              0x19
#define NDEF_URIPREFIX_BTGOEP               0x1A
#define NDEF_URIPREFIX_TCPOBEX              0x1B
#define NDEF_URIPREFIX_IRDAOBEX             0x1C
#define NDEF_URIPREFIX_FILE                 0x1D
#define NDEF_URIPREFIX_URN_EPC_ID           0x1E
#define NDEF_URIPREFIX_URN_EPC_TAG          0x1F
#define NDEF_URIPREFIX_URN_EPC_PAT          0x20
#define NDEF_URIPREFIX_URN_EPC_RAW          0x21
#define NDEF_URIPREFIX_URN_EPC              0x22
#define NDEF_URIPREFIX_URN_NFC              0x23
PN532.C (PN532 driver file)
//PN532.c
void spi_write_s(uint8_t c)
uint8_t i;
    // Software SPI write.
    digitalWrite(_clk, HIGH);
    for (i=0; i<8; i++) {
       digitalWrite(_clk, LOW);
      if (bit_test(c,i)==1)
        digitalWrite(_mosi, HIGH);
        digitalWrite(_mosi, LOW);
      delay(100);
      delay(100);
uint8_t spi_read_s(void)
  uint8_t i, x;
  x = 0;
    // Software SPI read.
    for (i=0; i<8; i++)
      if (digitalRead(_miso)==1)
       bit_set(x,i);
       bit_clear(x,i);
    delay(100);
    delay(100);
  // digitalWrite(_clk, LOW);
  return x;
void readdata(uint8_t* buff, uint8_t n)
    digitalWrite(_ss, LOW);
    delay(100);
    spi_write_s(PN532_SPI_DATAREAD);
    #ifdef PN532DEBUG
      printf("Reading: ");
    for (uint8_t i=0; i<n; i++) {
      delay(20);
      buff[i] = spi_read_s();
      //buff[i] = spi_xfer(0);
      #ifdef PN532DEBUG
        printf("0x%x ",buff[i]);
    #ifdef PN532DEBUG
      printf("\r\n");
    digitalWrite(_ss, HIGH);
    delay(100);
void writecommand(uint8_t* cmd, uint8_t cmdlen) {
    // SPI command write.
    uint8_t checksum;
    uint8_t i=0;
    cmdlen++;
    delay(100);
    checksum = PN532_PREAMBLE + PN532_PREAMBLE + PN532_STARTCODE2;
    delay(2000); // or whatever the delay is for waking up the board
    spi_write_s(PN532_SPI_DATAWRITE);
    spi_write_s(PN532_PREAMBLE);
    spi_write_s(PN532_STARTCODE2);
    spi_write_s(cmdlen);
    spi_write_s(((~cmdlen) + 1));
    spi_write_s(PN532_HOSTTOPN532);
    checksum += PN532_HOSTTOPN532;
    #ifdef PN532DEBUG
       printf("PN532_SPI_DATAWRITE: 0x%x\n\r",PN532_SPI_DATAWRITE);
       printf("PN532_PREAMBLE: 0x%x\n\r",PN532_PREAMBLE);
       printf("PN532_STARTCODE2: 0x%x\n\r",PN532_STARTCODE2);
       printf("cmdlen: 0x%x\n\r",cmdlen);
       printf("~cmdlen + 1: 0x%x\n\r",~cmdlen + 1);
       printf("PN532_HOSTTOPN532: 0x%x\n\r",PN532_HOSTTOPN532);
       printf("checksum += PN532_HOSTTOPN532: 0x%x\n\r", checksum);
    for (i=0; i<cmdlen-1; i++)
      spi_write_s(cmd[i]);
      checksum += cmd[i];
      #ifdef PN532DEBUG
        printf("cmd[%u]: 0x%x\n\r",i,cmd[i]);
    spi_write_s(~checksum);
    spi_write_s(PN532_POSTAMBLE);
    delay(100);
    #ifdef PN532DEBUG
      printf("~checksum: 0x%x\n\r",~checksum);
      printf("PN532_POSTAMBLE 0x%x\n\r",PN532_POSTAMBLE);
      printf("\r\n");
bool isready() {
 uint8_t x;
    // SPI read status and check if ready.
    delay(100);
    spi_write_s(PN532_SPI_STATREAD);
    delay(100);
     x = spi_read_s();
    delay(100);
    // Check if status is ready.
    if(x == PN532_SPI_READY) return 1;
      else return 0;
bool waitready(uint16_t timeout) {
  uint16_t timer = 0;
  while(!isready()) {
    if (timeout != 0) {
      timer += 10;
      if (timer > timeout) {
        printf("waitready TIMEOUT!\n\r");
        return false;
    delay(100);
  return true;
bool readack() {
  uint8_t ackbuff[6];
  readdata(ackbuff, 6);
  return (0 == memcmp((char *)ackbuff, (char *)pn532ack, 6));
bool sendCommandCheckAck(uint8_t *cmd, uint8_t cmdlen, uint16_t timeout) {
  // write the command
  writecommand(cmd, cmdlen);
  // Wait for chip to say its ready!
   if (!waitready(timeout)) {
    return false;
   // read acknowledgement
  if (!readack()) {
    #ifdef PN532DEBUG
      printf("No ACK frame received!\n\r");
    return false;
  // For SPI only wait for the chip to be ready again.
  // This is unnecessary with I2C.
      return false;
  return true; // ack'd command
uint32_t getFirmwareVersion(void) {
  uint32_t response;
  pn532_packetbuffer[0] = PN532_COMMAND_GETFIRMWAREVERSION;
  if (! sendCommandCheckAck(pn532_packetbuffer, 1,1000)) {
    return 0;
  // read data packet
  readdata(pn532_packetbuffer, 12);
  // check some basic stuff
  if (0 != memcmp((char *)pn532_packetbuffer, (char *)pn532response_firmwarevers, 6)) {
    return 0;
  int offset = 6 ;
  response = pn532_packetbuffer[offset++];
  response <<= 8;
  response |= pn532_packetbuffer[offset++];
  response <<= 8;
  response <<= 8;
  return response;
void PrintHex( byte* data,uint32_t numBytes)
  uint32_t szPos;
  for (szPos=0; szPos < numBytes; szPos++)
    printf("0x");
    printf("%2x",(data[szPos]&0xff));
    if ((numBytes > 1) && (szPos != numBytes - 1))
      printf(" ");
  printf("\r\n");
void PrintHexChar(byte* data,uint32_t numBytes)
  uint32_t szPos;
    printf("%2x",data[szPos]);
      printf(" ");
  printf("  ");
    if (data[szPos] <= 0x1F)
      printf(".");
      printf("%c",data[szPos]);
   printf("\r\n");
bool SAMConfig(void) {
  pn532_packetbuffer[0] = PN532_COMMAND_SAMCONFIGURATION;
  pn532_packetbuffer[1] = 0x01; // normal mode;
  pn532_packetbuffer[2] = 0x14; // timeout 50ms * 20 = 1 second
  pn532_packetbuffer[3] = 0x01; // use IRQ pin!
  if (! sendCommandCheckAck(pn532_packetbuffer, 4,1000))
    return false;
  // read data packet
  readdata(pn532_packetbuffer, 8);
  int offset = 5;
  return  (pn532_packetbuffer[offset] == 0x15);
void begin() {
    // SPI initialization
    //  setup_spi(SPI_MASTER|SPI_MODE_0|SPI_CLK_DIV_64);
    delay(100);
    // not exactly sure why but we have to send a dummy command to get synced up
    sendCommandCheckAck(pn532_packetbuffer, 1,1000);
    // ignore response!
    delay(100);
bool readPassiveTargetID(uint8_t cardbaudrate, uint8_t * uid, uint8_t * uidLength, uint16_t timeout) {
  pn532_packetbuffer[0] = PN532_COMMAND_INLISTPASSIVETARGET;
  pn532_packetbuffer[1] = 1;  // max 1 cards at once (we can set this to 2 later)
  pn532_packetbuffer[2] = cardbaudrate;
  if (!sendCommandCheckAck(pn532_packetbuffer, 3, timeout))
    #ifdef PN532DEBUG
     printf("No card(s) read\n\r");
    return 0x0;  // no cards read
  // read data packet
  readdata(pn532_packetbuffer, 20);
  /* ISO14443A card response should be in the following format:
    byte            Description
    b0..6           Frame header and preamble
    b7              Tags Found
    b8              Tag Number (only one used in this example)
    b9..10          SENS_RES
    b11             SEL_RES
    b12             NFCID Length
    b13..NFCIDLen   NFCID                                      */
  if (pn532_packetbuffer[7] != 1)
    return 0;
  uint16_t sens_res = pn532_packetbuffer[9];
  sens_res <<= 8;
  sens_res |= pn532_packetbuffer[10];
  /* Card appears to be Mifare Classic */
  *uidLength = pn532_packetbuffer[12];
  for (uint8_t i=0; i < pn532_packetbuffer[12]; i++)
    uid[i] = pn532_packetbuffer[13+i];
  return 1;
uint8_t ntag2xx_ReadPage (uint8_t page, uint8_t * buffer)
  // NTAG 203       42      4             39
  // NTAG 213       45      4             39
  if (page >= 231)
    return 0;
  /* Prepare the command */
  pn532_packetbuffer[0] = PN532_COMMAND_INDATAEXCHANGE;
  pn532_packetbuffer[1] = 1;                   /* Card number */
  pn532_packetbuffer[2] = MIFARE_CMD_READ;     /* Mifare Read command = 0x30 */
  pn532_packetbuffer[3] = page;                /* Page Number (0..63 in most cases) */
  /* Send the command */
    return 0;
  /* Read the response packet */
  readdata(pn532_packetbuffer, 26);
  /* If byte 8 isn't 0x00 we probably have an error */
  if (pn532_packetbuffer[7] == 0x00)
    /* Copy the 4 data bytes to the output buffer         */
    /* Block content starts at byte 9 of a valid response */
    /* Note that the command actually reads 16 byte or 4  */
    /* pages at a time ... we simply discard the last 12  */
    /* bytes                                              */
    memcpy (buffer, pn532_packetbuffer+8, 4);
    return 0;
  // Return OK signal
  return 1;
Try and Enjoy...
mohammad3d
PostPosted: Wed Oct 17, 2018 2:13 am     Reply with quote
The following is program output on serial port that captured with serial monitor software on PC computer...
Found chip PN532
Firmware ver. 1.6
  UID Length:7 bytes
  UID Value: 0x04 0x52 0xad 0xca 0x33 0x35 0x80
PAGE 00: 04 52 ad 73  .R s
PAGE 01: ca 33 35 80   35
PAGE 02: 4c 48 00 00  LH..
PAGE 03: e1 10 12 00   ...
PAGE 04: 00 00 00 00  ....
PAGE 05: 00 00 00 00  ....
PAGE 06: 00 00 00 00  ....
PAGE 07: 00 00 00 00  ....
PAGE 08: 00 00 00 00  ....
PAGE 09: 00 00 00 00  ....
PAGE 10: 00 00 00 00  ....
PAGE 11: 00 00 00 00  ....
PAGE 12: 00 00 00 00  ....
PAGE 13: 00 00 00 00  ....
PAGE 14: 00 00 00 00  ....
PAGE 15: 00 00 00 00  ....
PAGE 16: 00 00 00 00  ....
PAGE 17: 00 00 00 00  ....
PAGE 18: 00 00 00 00  ....
PAGE 19: 00 00 00 00  ....
PAGE 20: 00 00 00 00  ....
PAGE 21: 00 00 00 00  ....
PAGE 22: 00 00 00 00  ....
PAGE 23: 00 00 00 00  ....
PAGE 24: 00 00 00 00  ....
PAGE 25: 00 00 00 00  ....
PAGE 26: 00 00 00 00  ....
PAGE 27: 00 00 00 00  ....
PAGE 28: 00 00 00 00  ....
PAGE 29: 00 00 00 00  ....
PAGE 30: 00 00 00 00  ....
PAGE 31: 00 00 00 00  ....
PAGE 32: 00 00 00 00  ....
PAGE 33: 00 00 00 00  ....
PAGE 34: 00 00 00 00  ....
PAGE 35: 00 00 00 00  ....
PAGE 36: 00 00 00 00  ....
PAGE 37: 00 00 00 00  ....
PAGE 38: 00 00 00 00  ....
PAGE 39: 00 00 00 00  ....
PAGE 40: 00 00 00 00  ....
PAGE 41: 00 00 00 00  ....
H.JLS
I2C peripheral
PostPosted: Sun Dec 30, 2018 4:15 pm     Reply with quote
what's the basic lines of code that we have to change it to use the I2C peripheral between PIC16F and PN532 ?
Thank you.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
