18F2550 supported or not...
prayami
PostPosted: Mon Aug 08, 2005 6:42 pm     Reply with quote
I want to work on USB and have already ordered 18F2550. After that
I check in the devices folder but I couldn't find that processor header
file.
I got PCM and PCH CCS compiler. Does this chip is supported by CCS
or not?
What should I do?
Thanks in advanced....
PostPosted: Mon Aug 08, 2005 6:59 pm     Reply with quote
What version of the compiler do you have? I have the latest version, 3.230, and 18F2550.h is in the devices folder, so I assume it is supported.
prayami
PostPosted: Mon Aug 08, 2005 7:08 pm     Reply with quote
I got PCH version 3.212.24.16
and PCM 3.206.0.0
Is it not there in this version, what should I do?
mickey231bhq
PostPosted: Mon Aug 08, 2005 7:49 pm     Reply with quote
My version 3.230
Already Support Head file and USB function
Program Files\PICC\Devices\18F2550.h
prayami
PostPosted: Mon Aug 08, 2005 8:07 pm     Reply with quote
Any body know, whether is it available in 3.212.24.16 version or not?
Do I require to buy update ?
How much is the update is for?
Mark
PostPosted: Mon Aug 08, 2005 8:23 pm     Reply with quote
You should really take the time to do some reading. From the manual
ccsc +Q will show all the valid devices
If it is not in your version and you don't have the device editor, then of course you will have to buy an update if you do not already have update rights.
The cost? Look on CCS's site. There is a reason that it's published there!
rnielsen
PostPosted: Tue Aug 09, 2005 8:08 am     Reply with quote
The earliest version, that I still have installed, is v3.214. This version supports the 18F2550. Looking at the revision history, it looks like v3.213 had updates for newest chips. It's possible that this is the first version to support this PIC.
Ronald
