Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
PROBLEMS WITH #use delay(clock=4000000)
dax
PostPosted: Wed Aug 03, 2005 3:55 am     Reply with quote
Hi
Im working with PIC18LF4620 with 4 MHz external clock.
my header is
#include <18F4620.h>
#device ICD=TRUE
#fuses NOWDT,XT,NOPUT
#use rs232(DEBUGGER)
and the program never reach the main function, it remains at the #use delay(clock=4000000) line. The clock seems to work fine, my CCS compiler version its 3.224. If somebady knows abut this, all help its welcome,
thanks
dax
mickey231bhq
PostPosted: Wed Aug 03, 2005 4:14 am     Reply with quote
XT???? Very Happy
rnielsen
PostPosted: Wed Aug 03, 2005 8:42 am     Reply with quote
XT???? Very Happy
In other words, try using HS instead of XT. Anytime you are running at 4MHZ or faster you should use HS (High Speed) fuse.
Ronald
PostPosted: Wed Aug 03, 2005 12:42 pm     Reply with quote
Many PIC data sheets recommend XT for 4 MHz operation.
Examples:
16F877
16F877A
16F628
16F628A
18F452
I have used XT mode at 4 MHz on most of the PICs above with no problem.
For newer PICs, the data sheets give the option of using XT or HS mode
for a 4 MHz crystal. Examples:
16F88
16F688
18F4620
I don't think using XT mode is causing his problem.
It's more likely that he needs to add NOLVP to the #fuses statement.
That might fix the problem.
Kit
PostPosted: Wed Aug 03, 2005 9:15 pm     Reply with quote
use
#fuses NOWDT,HS,NOPUT
or you can add
#fuses NOWDT,HS, NOPUT, NOLVP
I only manage to get my PIC run after adding NOLVP.
if you dont want to use MCLR
#fuses NOWDT,HS, NOPUT, NOLVP, NOMCLR (try this first)
