problem whit pll h4 in pic18f6620
Roberto da Rivoli
PostPosted: Fri Jul 29, 2005 1:00 am     Reply with quote
Sad Sad
I use pic18f6620 with xtal 10 MHz and fuses HS, H4 set. but micro it works only to 10MHz
in fact the seriale works correctly only with
# use delay(clock=10000000)
PostPosted: Fri Jul 29, 2005 4:08 am     Reply with quote
You should only have H4 set, not 'HS'. However the patterns should 'OR' together without causing a problem.
Try with just H4.
If this fails, try adding a resistor _in series_ with your crystal of about 50R. There was a problem in the past on many PIC's, that the PLL, is sensitive to being overdriven, and will not run properly if the gain of the crystal is higher than expected. This is why the spec requires a parallel cut crystal. Adding the resistor can help if the crystal gain is just a little too high.
sseidman
PostPosted: Fri Jul 29, 2005 7:09 am     Reply with quote
Also, I seem to remember the need to actually power down the chip when changing between HS and H4
Scott
PostPosted: Fri Jul 29, 2005 1:36 pm     Reply with quote
sseidman is absolutely right. It caused me hours of troubleshooting in the past. You need to program the config, completely power down the PIC, and then it should be running with the PLL enabled.
I have used that exact circuit configuration in the past, PIC + 10MHz ceramic resonator without any problems.
Darren Rook
PostPosted: Mon Aug 01, 2005 7:03 am     Reply with quote
Also, there's a flaw in the 18F6620 in that it doesn't work properly over 25MHz.
