glavic
| PIC16F628A and LCD driver |
Posted: Wed Jul 13, 2005 10:56 am |
I am writing my own LCD driver, because driver included in CCS inst alowing you to define each pin.
main.c
| Code: | #include <16F628A.h>
#fuses NOWDT, PUT, NOPROTECT, BROWNOUT, NOMCLR, NOLVP, INTRC_IO, NOCPD
#include <driver.lcd.c>
void main ()
delay_ms(200);
lcd_init();
while (true)
driver.lcd.c
| Code: | #define LCD_rs PIN_B1
#define LCD_en PIN_B0
#define LCD_d4 PIN_B4
#define LCD_d5 PIN_B5
#define LCD_d6 PIN_B6
#define LCD_d7 PIN_B7
BYTE const LCD_INIT_STRING[5] =
0x28, // function set [2 lines, 5x10 dots]
0x10, // cursor or display shift [cursor move=off, shift to the left]
0x0C, // display on/off control [display=on, cursor displayed=off, cursor blinks=off]
0x06, // entry mode set [decrement, don't shift display]
0x01 // clear display
void lcd_clock ()
delay_us(2);
output_high(LCD_en);
delay_us(2);
output_low(LCD_en);
void lcd_send_nibble (byte n)
output_bit(LCD_d4, shift_right(&n,1,0) );
output_bit(LCD_d5, shift_right(&n,1,0) );
output_bit(LCD_d6, shift_right(&n,1,0) );
output_bit(LCD_d7, shift_right(&n,1,0) );
lcd_clock();
void lcd_send_cmd (byte n)
output_low(LCD_rs);
lcd_send_nibble(n >> 4);
delay_us(1);
lcd_send_nibble(n & 0x0F);
void lcd_init()
int count;
output_low(LCD_rs);
output_low(LCD_en);
delay_ms(15);
for (count=0; count < 3; ++count)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
for (count=0; count < 5; ++count)
lcd_send_cmd(LCD_INIT_STRING[count]);
Lcd doesnt want to intialize.
R/W pin is connected to the ground, because i wont read nothing from lcd, just write.
p.s. sory for my bad English. |
glavic
Posted: Wed Jul 13, 2005 4:43 pm |
| Tnx, it works. |
Kit Guest
Posted: Thu Jul 14, 2005 3:34 am |
When I tried to compile the source code vermontficks.com
the compiler said that "cSkip" is undefined.
I have read through again the source code, and i have no idea what is that.
btw, i commented the if (!cSkip) and it works.
Can anyone answer my questions? |
glavic
Posted: Thu Jul 14, 2005 4:08 am |
| Kit wrote: | When I tried to compile the source code vermontficks.com
Can anyone answer my questions? | Jep, cSkip is undefined.
Just change function > | Code: | #separate void LCD_PutChar ( unsigned int cX )
/* this subroutine works specifically for 4-bit Port A */
if ( !cSkip )
output_high ( LCD_RS );
LCD_SetData ( swap ( cX ) ); /* send high nibble */
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) ); /* send low nibble */
LCD_PulseEnable();
output_low ( LCD_RS );
to
LCD_PutCmd( cX );
guest Guest
Posted: Sun Jul 24, 2005 1:36 pm |
Same here,
No way that i am able to get the picc lcd driver running.
It works perfectly with the pic16f877, but not with the 84a or the 628a.
Why i dunno.
http://www.vermontficks.org/lcdc2.htm
This one works without any problem.
regards,
Evert |
guest Guest
Posted: Sun Jul 24, 2005 2:04 pm |
Same here,
Why i dunno.
regards,
Evert |
