ICD-U40 - What firmware to use
Dinesh
PostPosted: Fri Jul 15, 2005 12:54 pm     Reply with quote
I am new to CCS PCWH compiler and the ICD-U40.
I have downloaded the lastest updates but I am not sure where I can find the lastest firmware updates for ICD-U40. I have updated the driver and ICD sw.
On selecting debug from the compiler, I get a message that the ICD firmware is old and that i need to update it.
I noticed that latest firmware (2.01) in the ..\PICC directory is only 220k in size whilst the older (1.39) is 500k.
Can any one confirm this and what firmware should I be using to debug PIC18F452.
If a new firmware is required, where can I find it?
- Dinesh Question
treitmey
PostPosted: Fri Jul 15, 2005 3:52 pm     Reply with quote
When I bring up ICD program alone. On the bottom it says
CCS 1.39 REV#96 for PIC16 PIC18
This works great for me doing 18F452
Nandini
PostPosted: Tue Jul 19, 2005 3:22 pm     Reply with quote
1.39 is the latest ICD firmware. If the software complains it might be an issue with the software which would be fixed in the next release. Ignore the warning for now.
PICbastler
How to disable the Firmware-Warning?
PostPosted: Tue Aug 02, 2005 9:10 am     Reply with quote
Ive the same problem. My ICD-U40 uses the F/W 1.39.
After compiling there is the warning about the Firmware.
How can I disable this warning?
Confused
Firmware warning
PostPosted: Sun Aug 14, 2005 11:38 am     Reply with quote
remove icd-images-firmware-02-02.fw
