MikeValencia
| measure 105vac to 130vac line voltage |
Posted: Fri Jul 22, 2005 7:40 am |
I rectify the line voltage, nominally at 120vac to give me a motor bus voltage of approximately 170vdc. Since the line voltage can fluctuate on hot summer days and low power usage days between 105vac to 130vac, then my rectified motor bus voltage can then fluctuate from 148vdc to 184vdc
I also have a transformer which is nominally 12vac which i rectify and put thru a typical LM340 to give me 5v for the PIC.
I need a way to measure the line voltage without having to tap directly into the high voltage line. Is it okay to put a resistor voltage divider from the unregulated DC voltage feeding into the LM340? Perhaps i need a 5v zener to clamp that voltage?
I'm going on the assumption that a fluctuating line voltage would also cause my nominal 12vac to fluctuate, and i can directly measure the A/D voltage from the resistor divider i hook up to the unregulated DC to the LM340.
Is there a better way? |
Neutone
Posted: Fri Jul 22, 2005 7:50 am |
| I think ratiometric is the word. The rectified line voltage and the rectified transformer secondary will be ratiometric. If you have a capacitor between the rectifier and the regulator you can create a voltage divider across the capasitor to measure voltage. That would represent line voltage. |
MikeValencia
Posted: Fri Jul 22, 2005 8:15 am |
Yeah, i normally have a capacitor. In fact, i use a single 220uF electrolytic capacitor from my regulator input to Gnd, just like the PICDEM2-Plus.
I guess i'll have to use resistors sized at least 30K and 10K. This will give me current draw of 450uA at an unregulated 18VDC, and 4.5V across the bottom 10K resistor.
I've always taken the PIC's ADC characteristics for granted. Perhaps i'll have to preserve the 3:1 resistor ratio, but use something like 3k and 1k if it can't read reliably with those previous high resistances. |
SherpaDoug
Posted: Fri Jul 22, 2005 8:26 am |
I would use a seperate rectifier off of the 12AC winding to help isolate line voltage changes from DC load changes. Use a diode, a fairly small cap like 10uF, and a resistor divider in the vicinity of 10k to drive the A/D _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Fri Jul 22, 2005 10:33 am |
| You would be much better off using an OpAmp input to the PIC. Here is what I would do... Use the 12V after the transformer (since this should be ratiometric, w\ only slight deviations, to the high voltage line). Use an OPAMP with rail to rail inputs. This will allow you to get the correct impedance for the ADC as well as scaling from the opamp. You can make the gain of the op-amp 1/3 or so to further scale the voltage down. Also, make sure to diode clamp the input to the opamp. (If you don't use an opamp, be careful to diode clamp the PIC as it will not be happy with a -12V input). |
SherpaDoug
Posted: Fri Jul 22, 2005 11:46 am |
| Anonymous wrote: | | You would be much better off using an OpAmp input to the PIC. |
I don't see what you would gain by adding an Op Amp. If this were a battery powered application you could save a little bit of power but it doesn't sound like that matters much here. You can get as low an impedance as you could want by choosing the divider resistors. You could use a diode clamp to prevent spikes from damaging the A/D, but any spike on the secondary of the transformer would still trash the voltage regulator. I would rather put a MOV on the transformer to protect all the 12V loads. _________________ The search for better is endless. Instead simply find very good and get the job done. |
