yayodiaz44 Guest
| BIIIIIG PROBLEM. Help please. |
Posted: Fri Jul 15, 2005 1:31 pm |
Hi. I need your help. I really have a big problem.
I only want to know how can I access to a variable's bit?
I will be grateful with you all my life
Thank you. Don`t forget me
Alvaro |
Mark
Posted: Fri Jul 15, 2005 1:48 pm |
That's a little problem
There are a couple of ways but here is method:
bit_test(my_var,0)
bit_set(my_var,1)
bit_clear(my_var,2)
Posted: Fri Jul 15, 2005 1:50 pm |
| Quote: | | I only want to know how can I access to a variable's bit? |
Here are several ways to use bit variables in CCS:
| Code: | #include <16F877.H>
#use delay(clock = 4000000)
// Method 1:
// In CCS, the "short" data type is 1 bit.
// The compiler will handle assigning a RAM byte address
// to hold it. The compiler will put up to 8 "short"
// variables in that byte.
short my_short;
// Method 2:
// You can declare the byte variable yourself, and then
// declare bit variables within it, by using the #bit
// statement.
int8 my_var;
#bit my_bit0 = my_var.0
#bit my_bit1 = my_var.1
#bit my_bit2 = my_var.2
#bit my_bit3 = my_var.3
#bit my_bit4 = my_var.4
#bit my_bit5 = my_var.5
#bit my_bit6 = my_var.6
#bit my_bit7 = my_var.7
// Method 3:
// You can create a structure of bitfields that are 1 bit wide.
struct
short Bit0 : 1;
short Bit1 : 1;
short Bit2 : 1;
short Bit3 : 1;
short Bit4 : 1;
short Bit5 : 1;
short Bit6 : 1;
short Bit7 : 1;
}my_bits;
my_short = 1;
printf("my_short = %u \n\r", my_short);
my_bit0 = 1;
printf("my_bit0 = %u \n\r", my_bit0);
my_bits.Bit0 = 1;
printf("my_bits.Bit0 = %u \n\r", my_bits.Bit0);
