ChristophM
| board schematic |
Posted: Mon Jul 11, 2005 11:28 pm |
Hi
Does anyone have a board schematic with a pic18 and a Ethernet-Controller ENC28J60 or a RTL8019AS (eagle board schematic if possible)??
I need help,
Thanks Christoph |
Mark
Posted: Tue Jul 12, 2005 6:21 am |
I don't have any in Eage but I have them in PDF. Here is a link to a design using an RTL8019AS
http://www.compsys1.com/support/webdev/webdev.pdf
There should be a Microchip app note for the PICDEM.NET showing about the same thing.
I have a Microchip schematic using the ENC28J60 in PCAD. |
MikeValencia
Posted: Tue Jul 12, 2005 4:57 pm |
Are samples available yet?
I can't seem to find any. |
Mark
Posted: Tue Jul 12, 2005 6:02 pm |
| Depends on who you know. If you try and sample them from the website, then you probably won't be able to get them just yet. I've had some for quite a while. Since I work for a very big company, I tend to get things very soon because everyone wants to get their "foot in the door". |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Fri Aug 19, 2005 3:56 am |
FYI - I have just started playing with the ENC28J60. It is a lot more power hungry than the Realtek chip. If anyone has an operational implementation I would be interested in knowing if you implemented the output circuitry as per the datasheet or if you have an alternative implementation. _________________ Regards, Andrew
Mark
Posted: Fri Aug 19, 2005 4:41 am |
| asmallri wrote: | | FYI - I have just started playing with the ENC28J60. It is a lot more power hungry than the Realtek chip. If anyone has an operational implementation I would be interested in knowing if you implemented the output circuitry as per the datasheet or if you have an alternative implementation. |
I haven't had the time to try mine out yet. I did mine based on a schematic from Microchip. Email me and I'll reply back with the schematic I got from them. |
