Set tris doesn't work
KALKAN
PostPosted: Mon Jul 04, 2005 7:42 am     Reply with quote
I made down counter with LED display. I want to use RB0 to INT. I read set_tris_b(0b0000001). But I cant use INT. What can I do?
#include <16F628.h>
#use delay ( clock = 6000000 )
#fuses HS,NOWDT,NOPROTECT,NOLVP,nomclr
BYTE CONST LED_MAP[10] = {0x7e,0x0c,0xb6,0x9e,0xcc,0xda,0xfa,0x0e,0xfe,0xde};
char saya,sayac=9,say=9, say1=9,say2=9;
#INT_EXT
void ext_isr(void)
 static short button=TRUE;
if(button ){say--;}
void display_segs(char c)
output_b(LED_MAP[c]);
void display(char bir, char iki,char uc, ) {
   display_segs(bir);
      output_high(PIN_a0);
      delay_ms(5);
      output_low(PIN_a0);
   display_segs(iki);
      output_high(PIN_a1);
      delay_ms(5);
      output_low(PIN_a1);
   display_segs(uc);
      output_high(PIN_a2);
      delay_ms(5);
      output_low(PIN_a2);
void gos(void)
     if(say==-1)
      say1--;
      say=9;
   if(say1==-1)
      say2--;
      say1=9;
   if(say2==-1)
      say2=9;
   if(input(pin_a5))
      say=0, say1=0,say2=0;
  ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);
  set_tris_B(0x01);
  display(say, say1, say2);
   gos();
PostPosted: Mon Jul 04, 2005 8:04 am     Reply with quote
Do you have an external pullup on B0? If not, use:
enable_pullups(TRUE);
ckielstra
PostPosted: Mon Jul 04, 2005 8:08 am     Reply with quote
From the CCS manual chapter 'Data Definitions':
All types, except float, by default are unsigned; however, maybe preceded by unsigned or signed
Change your line to
signed int8 saya,sayac=9,say=9, say1=9,say2=9;
Also be make sure to add a switch debouncing meassure or the following line is due to fail:
     if(say==-1)
Your switch will trigger the interrupt multiple times, so the variable 'say' will be decremented multiple times and become smaller than -1.
Search this forum for debounce software. As another option you can create a hardware debounce from the Schmitt-trigger function of the Int-ext input and adding an external R/C combination with a time constant of minimal 10ms.
