meme
| Anyone used ENC28J60 ethernet controller with a PIC ? |
Posted: Sun Jul 03, 2005 5:05 am |
I am wondering if someone succcessfully used the ENC28J60 ethernet controller with a PIC. Can you simply transmit data, or you need to buffer it ? And one more question: the ENC28J60 can/must be programmed tu function properly ? or you simply send or recevie data through SPI and that's all ?
Thank you very much.
P.S. I am from Romania and I can't find this device. What is it's price ? |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Sun Jul 03, 2005 5:47 am |
I have not programmed it yet but plan to do shortly. It is an NE2000 compatible device so a lot of the exisitng PIC drivers out there should be relativley easy to port. If you search the web you will find several RTL8019A drivers for the PIC. This is also an NE2000 device but communication is via a parallel bus. I suspect this will be a good starting point for developing the ENC28J60.
UPDATE: I have started software development for the ENC28J60. It is radically different from the RTL8019A and my existing driver will be require a complete rewrite.
No. it is not a plug and play solution, drivers need to be developed / ported.
To find the device go to www.microchip.com - you will find the pricing on their site. Form memory it is around US$7 in single off quantities _________________ Regards, Andrew
Mark
Posted: Sun Jul 03, 2005 9:25 am |
| I think you will find most of your answers in the datasheet. Price, around $5. Have I used it successfully, well not yet but shortly. I have the raw PCB's and components. You can't buy the device just yet but you might be able to get samples. One errata with the device is that you must talk SPI @ 10MHz. |
valemike Guest
| One-Chip solution |
Posted: Sun Jul 03, 2005 11:54 am |
I know Freescale has one already.
Microchip is coming out with a micro that has an ethernet controller. So it's like having that ENJ part inside a PIC. |
meme
Posted: Sun Jul 03, 2005 2:50 pm |
| valemike, how soon will it be on the market ? do you have a link, or something ? |
valemike Guest
Posted: Sun Jul 03, 2005 8:11 pm |
It is called the PIC18F97J60. It is being pitched by some preliminary sales guys and FAEs as the "EtherPIC"
You can find a very few hits on Google. I don't know when they're coming out with it though. |
Mark
Posted: Mon Jul 04, 2005 12:39 am |
| valemike wrote: | It is called the PIC18F97J60. It is being pitched by some preliminary sales guys and FAEs as the "EtherPIC"
At least a year after any date they promise you!  |
treitmey
Posted: Tue Jul 05, 2005 7:55 am |
| What is part# for the freescale part that is out all ready? |
Mark
Posted: Tue Jul 05, 2005 7:56 am |
| MC9S12NE64 |
treitmey
Posted: Tue Jul 05, 2005 8:16 am |
Thanks.
I thought this was an interface. Turns out it is an mcu.
Thanks for the quick reply. |
Mark
Posted: Tue Jul 05, 2005 8:18 am |
| Yeah, that's what Mike was referring to. Problem I see with them is the limited amount of flash and SRAM. If you stuff the MAC inside the micro it takes up space. The space that is used for the flash and SRAM. |
| Re: Anyone used ENC28J60 ethernet controller with a PIC ? |
Posted: Sat Nov 19, 2005 4:54 am |
| meme wrote: | I am wondering if someone succcessfully used the ENC28J60 ethernet controller with a PIC. Can you simply transmit data, or you need to buffer it ? And one more question: the ENC28J60 can/must be programmed tu function properly ? or you simply send or recevie data through SPI and that's all ?
arunb
| RE |
Posted: Sat Nov 19, 2005 5:52 am |
I think it is not been released yet.
Is NE 2000 a good enough or are there better ones in the market. ??
thanks
arunb |
asmallri
Posted: Sat Nov 19, 2005 9:11 am |
The ENC28J60 is obviously easier and will offer higher performance for most PICs with SPI interfaces.
Another alternative is the AX88796L it is a 10/100 controller that is NE2000 ish. I have had a look at what is required to port a RealTek implementation to this and it is quite trivial. However, when you look at the maximum throughput you can achieve with a PIC driving an Ethernet controller there is really no value in a 10/100 interface as you cannot get to 10M anyway. For a project I am working on, I worked out I can achieve higher throughput with the ENC28J60 than with a 10/100 controller when using a 40M PIC18F MCU. It might be a different story with a PIC24F or dsPIC33.
The RealTek 8019AS is one of the most common 10M controllers used with PICs. _________________ Regards, Andrew
