younus_noman
| RS-232 |
Posted: Mon Jul 04, 2005 1:55 pm |
I am trying to receive data serially over RS-232 through LAB VIEW.
Lab view sends 3 bytes plus a termination character (0D ) at the end to PIC16f876 controller. Some how i am not able to read that termination character (0D) using getc().
Is it necessary for me to send a carriage return and a line feed at the end to read the 4th termination character?
Any ideas?
Noman Younus |
Posted: Mon Jul 04, 2005 2:08 pm |
getc() does not do any filtering or exclusion of characters.
See the test program below. It receives a character with getc()
and then displays it as a hex value in the terminal window.
When I type "ABCD" into my terminal program and press
the Enter key on my PC, I get the following output:
A 41
B 42
C 43
D 44
0D
| Code: | #include <16F877.H>
char c;
c = getc();
printf(" %X\n\r", c);
younus_noman
Posted: Mon Jul 04, 2005 2:37 pm |
Thanks for your quick reply..
I tried the above code before and i am able to display the hex value.
but when i say printf("ABCD \r\n") it displays ABCD on the hyper terminal whereas if i say printf("ABCD") without using the line feed and carriage return then it just displays ABC i.e. it chops of the last byte and i am not sure y it does that
I also did PIC to PIC commnication and displayed the recevied data on my LCD.
MASTER PIC sends---- printf("ABCD \n\r);
SLAVE PIC receives and displays ABCD
If i receive 6 bytes it displays ABCDAB (using getchar)
Noman Younus |
Mark
Posted: Mon Jul 04, 2005 2:42 pm |
| You must have a while(1) in your main. Most likely you do not, just the printf and nothing after that. What happens is that main finishes and there is a hidden sleep instruction in there. The last byte of data is still in the transmit buffer when the pic goes to sleep. Post your program if you don't understand what I am talking about. |
