ice
| Serial Comm. problem between 2 PICs |
Posted: Tue Jun 28, 2005 4:23 am |
Im trying to communicate between 2 pics ,with no success
The ADC value[10bit] from pic1 is transmitted to pic2.
i get a few values from pic 2 and then it stops receiving..
im working at 9600 baud ,20Mhx crystals and two PIC16f873A 's
My setup is in this format
PIC1(Hardware UART)
(Software UART)PIC2(Hardware UART)
PC COM Port
b is an array of char >>b[20]
Transmit routine:
test=read_adc();
delay_ms(10);
sprintf(b,"%lu",test);
puts(b);
Receive routine:
fgets(b,picpic);
x=atol(b);
fprintf(picpc,"%4lu\n",x);
Thank you _________________ **ice**
Machinegrid.com :: Robots at Work!! |
arunb
| RE: |
Posted: Tue Jun 28, 2005 5:25 am |
MCU: 16F877
Compiler: PCM 3.169
Have you specified the stream parameter in #use RS232 statement.
Eg.:
#use rs232(baud=9600,xmit=pin_c6, rcv=pin_c7,parity=n,brgh1ok,stream=PC)
#use rs232(baud=9600,xmit=pin_b1, rcv=pin_b2,parity=n,brgh1ok,stream=LASERCONTROLLER)
Here LASERCONTROLLER is the software USART, and PC the hatrdware one.
thanks
arunb |
Posted: Tue Jun 28, 2005 6:06 am |
Thanks for your reply ..yes i did specify the streams
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,stream=PicPc )
#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5,stream=PicPic )
| [/code] |
Mark
Posted: Tue Jun 28, 2005 6:08 am |
| fgets() reads until it receives a RETURN. You are not sending any that I can see. Also make sure that you have specified ERRORS in you #use RS232 statement. Personally I wouldn't use the fgets() function. Sure is an easy way to overrun a buffer. |
Posted: Tue Jun 28, 2005 6:55 am |
Yes.
It is far 'better', to include 'input.c', and use the 'get_string' function. This allows you to specify a maximum length for the string, which will 'block' if more characters arrive than expected, or re-code this to default to return when the string is full. :-)
