Another DS1307 driver
Goto page Previous  1, 2, 3  Next
faizkeats
An error
PostPosted: Sun Aug 01, 2010 12:23 am     Reply with quote
In last two statements where printf is used, it gives me an error:
Expecting a close paren
Can someone help me in this regard? Rest of the code is same as given above by Phil. Thanks.
matheuslps
PostPosted: Sun Dec 05, 2010 9:26 pm     Reply with quote
I know this is an old topic, but here the code worked like a charm! :D
BUT, can someone tell me what is dow? From:
ds1307_set_date_time(day,mth,year,dow,hour,min,sec)  Set the date/time
thanks
Phil
PostPosted: Mon Dec 06, 2010 2:08 am     Reply with quote
Day of week: 1 = Sunday, 2= Monday....7=Saturday
matheuslps
PostPosted: Mon Dec 06, 2010 6:43 am     Reply with quote
Thanks man!
ajaygautam.ic
PostPosted: Thu Apr 28, 2011 12:14 am     Reply with quote
Hi ,
I am new for this, please correct me if I am wrong.
This code is not looking a driver code. Means I am not able to get that where is the init_module, cleanup_module, device_open, device_release, device_read, device_ioctl functions in this code ?
Please clarify me.
--Thanx
Ajay Gautam
PostPosted: Thu Apr 28, 2011 11:13 am     Reply with quote
This is not a Linux driver. It's for small PIC micro-controllers, and is
written for the CCS C compiler. These micro-controllers don't have
an operating system.
Koslov
PostPosted: Wed May 11, 2011 11:42 am     Reply with quote
I've used that driver with a pic18f4550, but for some weird reason the display doesn't show the hours, and the minutes parameter freezes when arrive at 59 minutes, here's my code
#include "C:\Users\Koslov\Desktop\Electronica\C08 - Elec. Sistemes\rellotge_lcd\programa.h"
#define loader_end 0x7ff
#define loader_size 0x6ff
#build (reset=loader_end+1,interrupt=loader_end+9)
#org 9, loader_end{}
#include <ds1307.c>
#include <string.h>
#include <lcd2011_noread.c>
#include <ds1621M.c>
int min,sec,hrs,dow,month,yr,day,a;
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_64);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(False);
   init_temp(1);
  ds1307_init();
  ds1307_set_date_time(15,6,5,2,23,58,50);
      ds1307_get_time(hrs,min,sec);
      ds1307_get_date(day,month,yr,dow);
     // hh : mm : ss
     //1234567891234
      lcd_gotoxy(10,1);
      if(sec>9 ){
      printf(lcd_putc,": %u ",sec);}
      else{printf(lcd_putc,": 0%u",sec);}
      lcd_gotoxy(5,1);
      if(min>9){
      printf(lcd_putc,": %u ",min);}
      else{(lcd_putc,": 0%u",min);}
      lcd_gotoxy(2,1);
      if(hrs>9){(lcd_putc,"%u ",hrs);}
      else{(lcd_putc,"0%u ",hrs);}
      lcd_gotoxy(1,2);
      printf(lcd_putc,"%u - %u - %u : %u",day month yr dow);
can someone tell me how to solve this?
PostPosted: Wed May 11, 2011 1:39 pm     Reply with quote
Your printing code is too complicated. Test it with the example code
for main() in the first post in this thread.
If it doesn't work, then make a post in the main CCS forum.
It's better to have a long thread about problems in the main forum.
Koslov
PostPosted: Mon May 16, 2011 7:57 am     Reply with quote
Thank you PCM programmer, compiling the example program made me see the trouble was in my program, and its a noob one, I forgot to put printf function at the hours parameter Embarassed
mutthunaveen
same hang problem...now solved
PostPosted: Sun Nov 27, 2011 11:51 pm     Reply with quote
Hello
yesterday, when i first programmed DS1307 i got the same problem.. hanging and not refreshing auto resetting etc... i analyzed my code and did the following things
1. use proper pullup resistors for I2C communication (i used 10K) hardware not in software...
2. Use WDT for 500 - 800 ms as your PIC18F supports.
3. for first compilation set date and time and for next compilation comment set date and time function, and then load that again. (when WDT reset is done then there will be no resetting of time).
hope it will help Cool
small_chick
must set clock every run
PostPosted: Fri Jul 20, 2012 10:39 am     Reply with quote
hadeelqasaimeh wrote:
Its work fine with this driver but this mean i must set clock every run!!!!!!! How to avoid this?
I haven't understood what you mean, hadeelqasaimeh ! Would you mind explaining more clearly ? Thanks!
small_chick
PostPosted: Sat Jul 21, 2012 7:20 pm     Reply with quote
Phil, I'd like to ask you this:
1/- if I assign variables such as: date,year,hr,sec... in "char" or "int8" type => is it okay ?
2/- I've contracted 2 subroutines: bin2bcd & bcd2bin, as follow:
//subroutine converting BCD to Binary.
char bcd2bin(char bcd_value)
return((bcd_value >> 4) * 10 + (bcd_value & 0x0F));
//subroutine converting Binary to BCD.
char bin2bcd(char binary_value)
return( (swap(binary_value/10)) & (binary_value % 10));
if it has any problems, please let me know !
kaem1189
PostPosted: Sat Jun 01, 2013 8:20 pm     Reply with quote
I know that this is already a decade old thread. I am wondering why there is a ds1307_init() code. I think it makes no sense (unless there is function that stops the oscillator). init command fetch the value from seconds register and set oscillator enable bit and disable the squarewave output as well.. but ds1307_setdatetime also do those routine(except fetching seconds value of course)
freesat
ds1307 problems with interrupts
PostPosted: Mon Sep 16, 2013 6:09 pm     Reply with quote
I have used this code, it really works, but is not perfect. I have found errors when any timer(x) interrupt is enabled, this causes data written or read with errors, looks like interrupt is freezing code, then continues and data lost some bits.
Can anyone confirm that?
I'm not posting sample code because is not my code problem.
PostPosted: Tue Sep 17, 2013 1:59 pm     Reply with quote
Look at this driver code for the pcf8583. This driver assumes you are
using interrupts in another part of your main program:
http://www.ccsinfo.com/forum/viewtopic.php?t=27988
The routines that call CCS i2c library functions (i2c_start, i2c_write, etc).
are protected from interrupts by being enclosed with disable/enable lines
for Global interrupts.
I suggest that you edit the ds1307 driver routines and protect them in
the same way. See if that fixes the problem.
Page 2 of 3
