LCD help
Sophi
LCD help
PostPosted: Tue Jun 14, 2005 5:29 pm     Reply with quote
I am trying to print a variable (long int) from a function to an LCD screen.
printf(lcd_putc "\n%dblah blah", variable)
Any suggestions on the correct syntax and why this doesn't work? BTW it will compile if I typecast this variable as a float- but still not print.
Sophi
PostPosted: Tue Jun 14, 2005 5:33 pm     Reply with quote
You have to use "%LD" for 16 or 32-bit signed integers in CCS.
For unsigned integers, use "%LU".
I have put those in upper case so the "L" can be clearly seen,
but most people normally use lower case.
